		| Author | Message |
		| pikman
				| Driver for linear access of 8 memory 24LC512  512KB!! |
				|  Posted: Sun Jan 07, 2007 10:17 pm |   |
				| Hello, this simple driver allows to address 8 serial eeproms 24LC512 as one chip of 512KB (524.288 bytes),  in my develop it has been of a lot of help, I hope also helps.
 Ariel.
  	  | Code: |  	  | ///////////////////////////////////////////////////////////////////////////////////
 ////        Library for lineal address to a bank of 8 24LC512 chip memory      ////
 ////        0 to 0x07FFF                                                       ////
 //// init_24512x8();  Call before the other functions are used                 ////
 //// writeByte24512x8(a,d); Write the byte (int8)d to the address (int32)a     ////
 //// d=ReadByte24512x8(a); Read the byte int8)d from the address (int32)a      ////
 #ifndef EEPROM_SDA
 #define EEPROM_SDA  PIN_B1
 #define EEPROM_SCL  PIN_B0
 #use i2c(master, sda=EEPROM_SDA, scl=EEPROM_SCL)
 #define MULTIPLE_EEPROM_ADDRESS int32
 #define EEPROM_SIZE   524288
 void init_ext_eeprom()
 output_float(EEPROM_SCL);
 output_float(EEPROM_SDA);
 void writeByte_24512x8(int32 memaddress, int8 data){
 int16 address;
 int8  controlbyte;
 short int status;
 address=memaddress;
 controlbyte=(0xa0 | ((make8(memaddress,2))<<1));
 i2c_start();
 i2c_write(controlbyte);
 i2c_write(address>>8);
 i2c_write(address);
 i2c_write(data);
 i2c_stop();
 // AckNolege pooling
 i2c_start();
 status=i2c_write(controlbyte);
 while(status==1)
 i2c_start();
 i2c_stop();
 int8 readByte_24512x8(int32 memaddress){
 int16 address;
 int8  controlbyte;
 int8  data;
 address=memaddress;
 i2c_start();
 i2c_write(address);
 i2c_start();
 i2c_write(controlbyte|1);
 data=i2c_read(0);
 i2c_stop();
 return data;
		| BOB_SANTANA
				|  Posted: Mon Jan 08, 2007 3:34 pm |   |
				| Excellent Work Pikman
 Could you be kind enough just to do a quick example program
 Thanks in advance
 BOB_Santana
		| last_turk
				| 64K x 8 (512 Kbit) |
				|  Posted: Tue Mar 20, 2007 9:28 am |   |
				| 24AA512/24LC512/24FC512 (24XX512*) is a 64K x 8 (512 Kbit) and eeprom address must be 0 to 0xFFFF
 thanks for all
		| pikman
				|  Posted: Mon Apr 02, 2007 11:23 pm |   |
				| last_turk, I don't understant, my driver is to use whit 8 units 24AA512/24LC512/24FC512, is right you point there are 64KB (512 Kbit), but every one, 64kb x 8 = 512Kb ( or best 524288 bytes ), then adress you must enter is 0 to 0x07FFF,  and not  0 to      0xFFFF as you say, when you use this driver of course. |  |
		| treitmey
				|  Posted: Tue Apr 03, 2007 8:07 am |   |
				| According to spec sheet section 5.1 there are 19 bits of address A0->A15 and chip select bit A0,A1,A2.
 I wrote a simular driver for a FRAM FM24C256
 http://www.ccsinfo.com/forum/viewtopic.php?t=24099
 But in my driver I use a multi-read to speed things up.  And in that
 multi read my driver can go accross chip boundries.
 Have you thought about that?
 Here is your spec sheet.
 http://ww1.microchip.com/downloads/en/DeviceDoc/21754G.pdf
 see page 8   5.1 Contiguous Addressing Across Multiple Devices
 and page 9  6.2 Page Write ((what i call multiwrite)) up to 127 more writes.
 and 8.3 Sequential Read.
