erasing eeprom content
jelodavid
PostPosted: Tue Apr 19, 2005 3:48 pm     Reply with quote
Hello all!
Kindly help me on how to erase eeprom content...
Here's my partial code..........
// Save data to internal eeprom-----------------------------------------
void save_data()
   if (data1==0)
      lcd_putc("\fNo data to save...\n......Exiting");
      delay_ms(2000);
      return;
   printf(lcd_putc,"\fSaving %lu to\ninternal memory",data1);
   write_eeprom(address,make8(data1,0));
   address++;
   write_eeprom(address,make8(data1,1));
   address++;
   printf(lcd_putc,"\fMemory Save:  %lu",data1);
// Recall data from internal eeprom--------------------------------------
void recall_data()
   address=0;
      all_data = make16(read_eeprom(address+1),read_eeprom(address));
      delay_ms(30);
   printf(lcd_putc,"\fMemory Recall:\n  %lu",all_data);
   delay_ms(3000);
// Reset data from internal eeprom--------------------------------------
void reset_data()
   lcd_putc("\fResetting Data...");
   data1=0;
   write_eeprom(address,data1);
   lcd_putc("\fData reset");
eeprom content will reset to zero if it's below 255 but nothing happen above 255
PostPosted: Tue Apr 19, 2005 4:24 pm     Reply with quote
EEprom content will reset to zero if it's below 255 but nothing
happen above 255
void reset_data()
   data1=0;
Your code would be better, for various reasons, if your functions used
parameter variables instead of using global variables.
Your problem is due to a misunderstanding of this function:
The 2nd parameter, data1, is an 8-bit value. You can only write to
one byte of data eeprom each time the function is called. You're
assuming that it's a 16-bit value, and that you can erase two bytes
per function call. But you can't do that.
