jelodavid
Joined: 03 Apr 2005 Posts: 22 Location: Laguna Philippines
erasing eeprom content |
Posted: Tue Apr 19, 2005 3:48 pm |
Hello all!
Kindly help me on how to erase eeprom content...
Here's my partial code.......... Code: | // Save data to internal eeprom-----------------------------------------
void save_data()
if (data1==0)
lcd_putc("\fNo data to save...\n......Exiting");
delay_ms(2000);
return;
printf(lcd_putc,"\fSaving %lu to\ninternal memory",data1);
write_eeprom(address,make8(data1,0));
address++;
write_eeprom(address,make8(data1,1));
address++;
printf(lcd_putc,"\fMemory Save: %lu",data1);
// Recall data from internal eeprom--------------------------------------
void recall_data()
address=0;
all_data = make16(read_eeprom(address+1),read_eeprom(address));
delay_ms(30);
printf(lcd_putc,"\fMemory Recall:\n %lu",all_data);
delay_ms(3000);
// Reset data from internal eeprom--------------------------------------
void reset_data()
lcd_putc("\fResetting Data...");
data1=0;
write_eeprom(address,data1);
lcd_putc("\fData reset");
eeprom content will reset to zero if it's below 255 but nothing happen above 255 |
Posted: Tue Apr 19, 2005 4:24 pm |
Quote: | EEprom content will reset to zero if it's below 255 but nothing
happen above 255 |
void reset_data()
data1=0;
Your code would be better, for various reasons, if your functions used
parameter variables instead of using global variables.
Your problem is due to a misunderstanding of this function:
The 2nd parameter, data1, is an 8-bit value. You can only write to
one byte of data eeprom each time the function is called. You're
assuming that it's a 16-bit value, and that you can erase two bytes
per function call. But you can't do that. |
