what is the problem with my manchester en(de)coding program?
Goto page Previous  1, 2, 3
PostPosted: Mon Feb 28, 2005 4:21 pm     Reply with quote
Do I need to change the send date (decoding method), or just keep it that way, and using UARD on the receiver side?
Humberto
PostPosted: Mon Feb 28, 2005 6:11 pm     Reply with quote
You must use both functions:
In the Tx side
int8 j;
         putc(0xF0); // 0b11110000
         putc(0xF0); // Sync pulses used in the receiver side to wake up
         putc(0xF0); // Note also that 11 and 00 are forbiden according to
                     // Manchester rules, but they will be usefull as a
                     // Data Preamble.
         for(j='A'; j<='D'; j++)
            {            // 'A' 'B' 'C' 'D'  = 8 bytes encoded
              SEND_DATA(j);
         putc(0x0F); // 0b00001111
         putc(0x0F); // Note also that 00 and 11 are forbiden according to
         putc(0x0F); // Manchester rules, but they will be usefull as a
                     // Data Postamble.
         delay_ms(2000);
In the Rx side:
int8 Rx_buffer[15];
int8 data, index, j;
int8 some_char_recved;
        if(kbhit())
           do
              data = getc();
              if(data==0xF0)
                {index = 0;}
                {index++; }
              if(index>=15)
                {some_char_recved = TRUE;}
              Rx_buffer[index] = data;
             }while(!some_char_recved);
    if(some_char_recved)
       for(j=0; j<=15; j++)   // Print out the encoded receiver buffer
           printf("%X", Rx_buffer[j]);
          {                          // Print out the received Data decoded
           data = Rx_buffer[j];
           if((data !=0xF0) && (data != 0x0F))
              data = DECODE_DATA(Rx_buffer[j]);
              printf("%C", data);
        some_char_recved = FALSE;
Not tested nor compiled. Writted on line.
Humberto
PostPosted: Mon Feb 28, 2005 6:36 pm     Reply with quote
so in this way, I have to use rs232 RCV, TX pin, right? no need to define another pin as TX and RCV?
Humberto
PostPosted: Mon Feb 28, 2005 8:27 pm     Reply with quote
You must use rs232 in the regular mode, but:
In the Tx Side, Tx_PIN should be wired to TWS434 input.
In the Rx Side, Rx_PIN should be wired from RWS434 output.
Be sure that the iddle state of the receiver is HIGH,
if not reverse the START bit detect and the decoding bit test:
        if(kbhit())                   if(!kbhit())
Humberto
PostPosted: Tue Mar 01, 2005 4:48 am     Reply with quote
Sorry, I forgot this:
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, STREAM=Comm)
#use rs232(baud=2400, xmit=PIN_B1, rcv=PIN_B0, STREAM=RF)
In Tx side replace
    putc()   by fputc(...RF)
    printf() by fprintf(RF, ...)
In Rx side:
    if(kbhit(RF))
       do
          data = fgetc(RF);
         }while........
    fprintf(Comm, .........);
Humberto
PostPosted: Tue Mar 01, 2005 7:21 am     Reply with quote
Thank you Humberto:
After a long journey, we came to what I first asked for in the first post. but with a more clear idea about how manchester is working. uisng both way I could sending data correctly, the problem is the receiving, this problem have bother me for a whole week, I hope I could find a quick soon.
Humberto
PostPosted: Tue Mar 01, 2005 8:37 am     Reply with quote
Hi young,
You are right, but let´s assume that in the beggining of this thread
you was so confused that I preffer the little endian mode. Very Happy
Regarding receiving this kind of signal, you will need a work around
to improve the reception, a good scope is a must.
Be aware that this links are limited to short distances (~30m)
Hope you write us the final chapter of this story... Wink
Saludos,
Humberto
PostPosted: Tue Mar 01, 2005 8:55 am     Reply with quote
Thank you:
I know it is wired to ask the following question before I solve this one, but I would like to keep awared of the future option. The question is If I want to send data much longer distance than this one, what should I do?
PostPosted: Tue Mar 01, 2005 9:30 am     Reply with quote
Humberto:
I finally could see my program running using the following code, but I still have a minor problem, That this I could send and received data correclty with very little noise, however, When I want to send data more than 2, there is some unwanted data.
here is the case, when I send 'A', "AB", using my program, it is working find, when I send "ABC", there is unwanted data, here is the output, what might be the problem:
ABCABCABCABCABCABCABCA$4$4$4$4$4$4$4$4$4$4$4$4$
4$4$4$4$4$4$4$4$ABCABCABCABCABCABCABCABCABCABCABCABCABCABCABCABCABCABCABCABCA$4$4$4$4$4$4$4$4$4$4$4$4$4$4$4$4$4$4$4$4$ABCAB
CABCABCABCABCABCABCABCABCABCABCABCABCABCABCABCABCABCABCA$4$ô$4$4$4$4$4$4$4$4$4$4$4$4$4$4$4$4$4$4$ABCABCABCABCABCABCABCABCAB
CABCABCABCABCABCABCABóABCABCABCABCA$4$4$4$4$4$4$4$4$4$4$4$4$4$4$4$4$4$4$4$4$ABCABCABCABCABCABCABCABCABCABCABCABCABCABCABCAB
CABCABCABCABCA$4$4$4$4$4$4$4$4$4$4$4$4$4$4$4$4$4$4$4$4$ABCABCABC
here is my program
#if defined(__PCM__)
#include <16F819.h>
#include <stdio.h>
#include <stdlib.h>
#fuses HS,WDT,NOPROTECT
//#device ADC=10
#use delay(clock=10000000)
#use rs232(baud=2400, parity=N, xmit=PIN_A0, rcv=PIN_A1)
void SEND_DATA(BYTE txbyte)
    int i,j,b,me;
    b = txbyte;
    for (i=0; i<2; i++)
        delay_ms(10);
        me = 0;         // manchester encoded txbyte
        for (j=0 ; j<4; j++) {
            me >>=2;
            if (bit_test(b,0) )
                me |= 0b01000000; // 1->0
                me |= 0b10000000; // 0->1
            b >>=1;
        putc(me);
void remoteprintf(char *c)
   int8 i,length;
   length=strlen(c);
   //premable data to init TWS
    putc(0xF0);
    delay_us(500); // *
    putc(0xF0);
    delay_us(500); //
    putc(0xF0);
    delay_us(500); // *
    putc(0xF0);
    delay_us(500); //
   for (i=0; i<length;i++)
     { SEND_DATA(c[i]);
     putc(0xF0);
     delay_us(500);
  char data[]="AB";
   setup_port_a(ADC_OFF);
   setup_CCP1(CCP_OFF);
   setup_timer_1(T1_DISABLED);
   enable_interrupts(global);
   remoteprintf(data);
decoding
/*      Decoding Manchester data bit by bit              */
#include <16F819.h>
#Device *=16
#include <stdio.h>
#include <stdlib.h>
#fuses HS,NOWDT,NOPROTECT,NOBROWNOUT
//#device ADC=10
#use rs232(baud=2400, parity=N, xmit=PIN_A0, rcv=PIN_A1,ERRORS)
#define M_Rx_Pin PIN_B0
int16 data_ori[40];
char data_decod[40];
char status;  //data 1 start 0 stop
int8 bit_num,data_num,i,j,k;
int1 tem;
BYTE DECODE_DATA(BYTE encoded)
    BYTE i,dec,enc,pattern;
    enc = encoded;
    if (enc == 0xf0)    //  start/end condition encountered
        return 0xf0;
    dec = 0;
    for (i=0; i<4; i++) {
        dec >>=1;
        pattern = enc & 0b11;
        if (pattern == 0b01)        // 1
            bit_set(dec,3);
        else if (pattern == 0b10)
            bit_clear(dec,3);       // 0
            return 0xff;            // illegal code
        enc >>=2;
    return dec;
  char data1[20],datar,ddl,ddh,datadecode;
  char status;  //data pre and post part
   SET_TRIS_b(0xff);
   set_Tris_a(0x00);
   SETUP_CCP1(CCP_OFF);
   SETUP_ADC_PORTS(NO_ANALOGS);
   disable_interrupts(INT_EXT);
   disABLE_INTERRUPTS(GLOBAL);
   status=0;  //lsb part
   datadecode=0;
    if (!kbhit())
      datar = getc();
      if(datar!=0xf0)
          ddh=DECODE_DATA(datar);
          if(status==0)
            status=1;
            ddl=ddh;
            status=0;
            ddh<<=4;
            datadecode=(ddh | ddl);
            putc(datadecode);
Humberto
PostPosted: Tue Mar 01, 2005 12:14 pm     Reply with quote
Great ! ! ! It´s running.
With this arrangement I guess that it´s almost all you can expect,
I assume that the antenna was tunned/installed properly.
RF links with AM transmiters in milliwatt range is not a reliable
configuration by design. To improve the data integrity and reliability,
you can add it some easy improvements like
error detecting + redundance technique
wich is transmitting the same packet more than once and validating
the received data by simple majority.
best wishes,
Humberto
PostPosted: Tue Mar 01, 2005 12:58 pm     Reply with quote
In the receivr, I reallized that some times the data wwasvery low, which at this period, data was misdecoded. why sometime the receiver side sometime have strong signal, sometime has weak signal.
young
PostPosted: Tue Mar 01, 2005 4:21 pm     Reply with quote
I combined error check and data sending some special character. right now I am able to send whatever length of data I want.
A curious question? At my sending side, some times data is not sent out, I could not see data in the oscope. why?
Page 3 of 3
