Posted: Mon Feb 28, 2005 4:21 pm |
| Do I need to change the send date (decoding method), or just keep it that way, and using UARD on the receiver side? |
Humberto
Posted: Mon Feb 28, 2005 6:11 pm |
You must use both functions:
In the Tx side
int8 j;
putc(0xF0); // 0b11110000
putc(0xF0); // Sync pulses used in the receiver side to wake up
putc(0xF0); // Note also that 11 and 00 are forbiden according to
// Manchester rules, but they will be usefull as a
// Data Preamble.
for(j='A'; j<='D'; j++)
{ // 'A' 'B' 'C' 'D' = 8 bytes encoded
SEND_DATA(j);
putc(0x0F); // 0b00001111
putc(0x0F); // Note also that 00 and 11 are forbiden according to
putc(0x0F); // Manchester rules, but they will be usefull as a
// Data Postamble.
delay_ms(2000);
In the Rx side:
int8 Rx_buffer[15];
int8 data, index, j;
int8 some_char_recved;
if(kbhit())
do
data = getc();
if(data==0xF0)
{index = 0;}
{index++; }
if(index>=15)
{some_char_recved = TRUE;}
Rx_buffer[index] = data;
}while(!some_char_recved);
if(some_char_recved)
for(j=0; j<=15; j++) // Print out the encoded receiver buffer
printf("%X", Rx_buffer[j]);
{ // Print out the received Data decoded
data = Rx_buffer[j];
if((data !=0xF0) && (data != 0x0F))
data = DECODE_DATA(Rx_buffer[j]);
printf("%C", data);
some_char_recved = FALSE;
Not tested nor compiled. Writted on line.
Humberto |
Posted: Mon Feb 28, 2005 6:36 pm |
| so in this way, I have to use rs232 RCV, TX pin, right? no need to define another pin as TX and RCV? |
Humberto
Posted: Mon Feb 28, 2005 8:27 pm |
You must use rs232 in the regular mode, but:
In the Tx Side, Tx_PIN should be wired to TWS434 input.
In the Rx Side, Rx_PIN should be wired from RWS434 output.
Be sure that the iddle state of the receiver is HIGH,
if not reverse the START bit detect and the decoding bit test:
if(kbhit()) if(!kbhit())
Humberto |
Posted: Tue Mar 01, 2005 4:48 am |
Sorry, I forgot this:
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, STREAM=Comm)
#use rs232(baud=2400, xmit=PIN_B1, rcv=PIN_B0, STREAM=RF)
In Tx side replace
putc() by fputc(...RF)
printf() by fprintf(RF, ...)
In Rx side:
if(kbhit(RF))
do
data = fgetc(RF);
}while........
fprintf(Comm, .........);
Humberto |
Posted: Tue Mar 01, 2005 7:21 am |
Thank you Humberto:
After a long journey, we came to what I first asked for in the first post. but with a more clear idea about how manchester is working. uisng both way I could sending data correctly, the problem is the receiving, this problem have bother me for a whole week, I hope I could find a quick soon. |
Humberto
Posted: Tue Mar 01, 2005 8:37 am |
Hi young,
You are right, but let´s assume that in the beggining of this thread
you was so confused that I preffer the little endian mode.
Regarding receiving this kind of signal, you will need a work around
to improve the reception, a good scope is a must.
Be aware that this links are limited to short distances (~30m)
Hope you write us the final chapter of this story...
Saludos,
Humberto |
Posted: Tue Mar 01, 2005 8:55 am |
Thank you:
I know it is wired to ask the following question before I solve this one, but I would like to keep awared of the future option. The question is If I want to send data much longer distance than this one, what should I do? |
Posted: Tue Mar 01, 2005 9:30 am |
Humberto:
I finally could see my program running using the following code, but I still have a minor problem, That this I could send and received data correclty with very little noise, however, When I want to send data more than 2, there is some unwanted data.
here is the case, when I send 'A', "AB", using my program, it is working find, when I send "ABC", there is unwanted data, here is the output, what might be the problem:
| Quote: |
ABCABCABCABCABCABCABCA$4$4$4$4$4$4$4$4$4$4$4$4$
4$4$4$4$4$4$4$4$ABCABCABCABCABCABCABCABCABCABCABCABCABCABCABCABCABCABCABCABCA$4$4$4$4$4$4$4$4$4$4$4$4$4$4$4$4$4$4$4$4$ABCAB
CABCABCABCABCABCABCABCABCABCABCABCABCABCABCABCABCABCABCA$4$ô$4$4$4$4$4$4$4$4$4$4$4$4$4$4$4$4$4$4$ABCABCABCABCABCABCABCABCAB
CABCABCABCABCABCABCABóABCABCABCABCA$4$4$4$4$4$4$4$4$4$4$4$4$4$4$4$4$4$4$4$4$ABCABCABCABCABCABCABCABCABCABCABCABCABCABCABCAB
CABCABCABCABCA$4$4$4$4$4$4$4$4$4$4$4$4$4$4$4$4$4$4$4$4$ABCABCABC
here is my program
#if defined(__PCM__)
#include <16F819.h>
#include <stdio.h>
#include <stdlib.h>
#fuses HS,WDT,NOPROTECT
//#device ADC=10
#use delay(clock=10000000)
#use rs232(baud=2400, parity=N, xmit=PIN_A0, rcv=PIN_A1)
void SEND_DATA(BYTE txbyte)
int i,j,b,me;
b = txbyte;
for (i=0; i<2; i++)
delay_ms(10);
me = 0; // manchester encoded txbyte
for (j=0 ; j<4; j++) {
me >>=2;
if (bit_test(b,0) )
me |= 0b01000000; // 1->0
me |= 0b10000000; // 0->1
b >>=1;
putc(me);
void remoteprintf(char *c)
int8 i,length;
length=strlen(c);
//premable data to init TWS
putc(0xF0);
delay_us(500); // *
putc(0xF0);
delay_us(500); //
putc(0xF0);
delay_us(500); // *
putc(0xF0);
delay_us(500); //
for (i=0; i<length;i++)
{ SEND_DATA(c[i]);
putc(0xF0);
delay_us(500);
char data[]="AB";
setup_port_a(ADC_OFF);
setup_CCP1(CCP_OFF);
setup_timer_1(T1_DISABLED);
enable_interrupts(global);
remoteprintf(data);
decoding
/* Decoding Manchester data bit by bit */
#include <16F819.h>
#Device *=16
#include <stdio.h>
#include <stdlib.h>
#fuses HS,NOWDT,NOPROTECT,NOBROWNOUT
//#device ADC=10
#use rs232(baud=2400, parity=N, xmit=PIN_A0, rcv=PIN_A1,ERRORS)
#define M_Rx_Pin PIN_B0
int16 data_ori[40];
char data_decod[40];
char status; //data 1 start 0 stop
int8 bit_num,data_num,i,j,k;
int1 tem;
BYTE DECODE_DATA(BYTE encoded)
BYTE i,dec,enc,pattern;
enc = encoded;
if (enc == 0xf0) // start/end condition encountered
return 0xf0;
dec = 0;
for (i=0; i<4; i++) {
dec >>=1;
pattern = enc & 0b11;
if (pattern == 0b01) // 1
bit_set(dec,3);
else if (pattern == 0b10)
bit_clear(dec,3); // 0
return 0xff; // illegal code
enc >>=2;
return dec;
char data1[20],datar,ddl,ddh,datadecode;
char status; //data pre and post part
SET_TRIS_b(0xff);
set_Tris_a(0x00);
SETUP_CCP1(CCP_OFF);
SETUP_ADC_PORTS(NO_ANALOGS);
disable_interrupts(INT_EXT);
disABLE_INTERRUPTS(GLOBAL);
status=0; //lsb part
datadecode=0;
if (!kbhit())
datar = getc();
if(datar!=0xf0)
ddh=DECODE_DATA(datar);
if(status==0)
status=1;
ddl=ddh;
status=0;
ddh<<=4;
datadecode=(ddh | ddl);
putc(datadecode);
Humberto
Posted: Tue Mar 01, 2005 12:14 pm |
Great ! ! ! It´s running.
With this arrangement I guess that it´s almost all you can expect,
I assume that the antenna was tunned/installed properly.
RF links with AM transmiters in milliwatt range is not a reliable
configuration by design. To improve the data integrity and reliability,
you can add it some easy improvements like
error detecting + redundance technique
wich is transmitting the same packet more than once and validating
the received data by simple majority.
best wishes,
Humberto |
Posted: Tue Mar 01, 2005 12:58 pm |
| In the receivr, I reallized that some times the data wwasvery low, which at this period, data was misdecoded. why sometime the receiver side sometime have strong signal, sometime has weak signal. |
young
Posted: Tue Mar 01, 2005 4:21 pm |
I combined error check and data sending some special character. right now I am able to send whatever length of data I want.
A curious question? At my sending side, some times data is not sent out, I could not see data in the oscope. why? |
