		| Author | Message |
		| Darren Logan Guest
				| Wanted : A simple USB example |
				|  Posted: Tue May 27, 2003 3:51 pm |   |
				| Hello there,
 Does anyone have a simple PIC to PC USB example (written in CCS C obviously)?
 If so, I would be very greatful if you would let me have the code.
 Admittadly, I do not understand USB fully - however all I would like to be able to do is have the PC communicate with a PIC (say send strings back and forth) in a simple no-brainer mannor!.
 Am I right in thinking that one has to have a Vendor ID in order to use USB?
 I think the earlier I get into this the better, as USB is obviously taking off "big style" - as they say.
 Any help appreciated. Cheers!
 Regards,
 Darren
 ___________________________
 Original Post ID: 144514797
		| alexz
				|  Posted: Thu Oct 14, 2004 5:23 am |   |
				| I would like to have it as well  _________________
 Alex
		| Mark
				|  Posted: Thu Oct 14, 2004 5:56 am |   |
				| Look in your examples & drivers directories.  There are several there. |  |
		| asmallri
				|  Posted: Thu Oct 14, 2004 7:09 am |   |
				| Code for the FTDI245....
  	  | Code: |  	  | #include .... // include CPU specific header and port definitions
 #define   TxCQsize   64   // Console Tx buffer size
 #define   RxCQsize   64   // Console Tx buffer size
 //; Console Rx Ring Buffer control
 byte   Rx_HeadC;
 byte   Rx_TailC;
 //; Console Tx Ring Buffer control
 byte   Tx_HeadC;
 byte   Tx_TailC;
 byte   Tx_BaseC[TxCQsize];
 // Console Rx buffer
 byte   Rx_BaseC[RxCQsize];
 void console_putc(char TxChar)
 ; Subroutine console_putc
 ;   Stdout routine (BLOCKING) for putting characters to the console interface.
 ; On Exit:
 long counter = 65535;   // setup counter to prevent lockup on failure of USB
 //; test to determine if the USB device is active
 if (!bit_test(USB_PwrEn))
 while ((counter!=0) && bit_test(USB_WRF))
 counter--;
 if (Counter)
 DBus = TxChar;      //; write the character to the data bus
 bit_set(USB_WR);
 DBusDir = 0;      //; set data bus to output
 bit_clear(USB_WR);
 DBusDir = 0xff;      //; set data bus to input
 // timeout waiting on USB
 // .. do something else here such as write to serial port
 putc(TxChar);
 //; USB port not active, do something else like pass control to the async port code
 putc(TxChar);
 bit console_kbhit(void)
 // test to determine if the USB device is active
 return ((!bit_test(USB_PwrEn)) && (!bit_test(USB_RDF)));
 char console_getc(void)
 char Rx_Char = 0x00;
 // if not active pass exit
 if ((!bit_test(USB_PwrEn)) && (!bit_test(USB_RDF)))
 //  here we have a character in the USB controller
 DBusDir = 0xFF;      // set the data bus to input
 bit_clear(USB_RD);
 Rx_Char = DBus;
 bit_set(USB_RD);
 return (Rx_Char);
 init_pic();
 //; initialise the I/O lines to the USB controller
 bit_set(USB_FLUSH);   //; initialise the flush FIFO pin
 bit_clear(USB_WR);     //; set default WR level
 bit_set(USB_RD);      //; set default RD level
 //; initialise Console receive buffer pointers
 Rx_HeadC = 0;
 Rx_TailC = 0;
 //; initialise Console transmit buffer pointers
 Tx_HeadC = 0;
 Tx_TailC = 0;
 printf(console_putc,"Hello, world\r\n");
 //ExecLoop
 while (1)
 // do something
 // don't forget to scan the USB device
 // note that the FTDI245 has a large input buffer
 // there is not need to do a buffer to buffer copy
 Have fun....
		| alexz
				|  Posted: Thu Oct 14, 2004 7:28 am |   |
				| Has anybode got a code for the USBN9603 _________________
 Alex
		| Mark
				|  Posted: Thu Oct 14, 2004 8:16 am |   |
				| Like I said, CCS gives it to you:
  	  | Code: |  	  | /////////////////////////////////////////////////////////////////////////
 ////                      usbn960x.c                                 ////
 ////    National USBN960x Hardware layer for CCS's PIC USB driver.   ////
 //// This file is part of CCS's PIC USB driver code, which includes: ////
 ////   usb_desc_*.h - an example set of config and device descriptor ////
 ////   usb.c - USB token and request handler code                    ////
 ////   usb.h - definitions, prototypes and global variables          ////
 //// usbn960x.c is the hardware layer level driver for the CCS PIC   ////
 //// USB driver.  You can replace usbn960x.c with another hardware   ////
 //// layer level and still use the other parts of the PIC USB        ////
 //// driver.                                                         ////
 //// Three examples are given using CCS's PIC USB driver.            ////
 //// ex_usb_scope.c is a bulk device that sends 512 bytes to the     ////
 //// host and uses the USBN960x.  ex_usb_hid.c is a HID device and   ////
 //// uses the PIC16C7x5 or USBN960x.  ex_usb_mouse.c is a HID mouse  ////
 //// and uses the PIC16C7x5 or USBN960x.                             ////
 //// This example USB peripheral layer was written and tested with   ////
 //// CCS's USB Full Speed demo board.  When using your own design,   ////
 //// either wire your USB960x the same as our demo board or change   ////
 //// the port and pin definitions below.                             ////
 ////   *************************  NOTE  **************************   ////
 //// This driver uses INT_EXT.  It requires INT_EXT to interrupt the ////
 //// PIC when an event has happened on the USBN960x.  Because of     ////
 //// this code enables interrupts.  A user modification can be made  ////
 //// to poll the USBN960x device instead of relying on an interrupt. ////
		| alexz
				|  Posted: Thu Oct 14, 2004 8:21 am |   |
				| Yeah, I ve found it now, thanks _________________
 Alex
		| Guest
