Wanted : A simple USB example
Darren Logan
PostPosted: Tue May 27, 2003 3:51 pm     Reply with quote
Hello there,
Does anyone have a simple PIC to PC USB example (written in CCS C obviously)?
If so, I would be very greatful if you would let me have the code.
Admittadly, I do not understand USB fully - however all I would like to be able to do is have the PC communicate with a PIC (say send strings back and forth) in a simple no-brainer mannor!.
Am I right in thinking that one has to have a Vendor ID in order to use USB?
I think the earlier I get into this the better, as USB is obviously taking off "big style" - as they say.
Any help appreciated. Cheers!
Regards,
Darren
___________________________
Original Post ID: 144514797
alexz
PostPosted: Thu Oct 14, 2004 5:23 am     Reply with quote
I would like to have it as well Razz
Alex
Mark
PostPosted: Thu Oct 14, 2004 5:56 am     Reply with quote
Look in your examples & drivers directories. There are several there.
asmallri
PostPosted: Thu Oct 14, 2004 7:09 am     Reply with quote
Code for the FTDI245....
#include .... // include CPU specific header and port definitions
#define   TxCQsize   64   // Console Tx buffer size
#define   RxCQsize   64   // Console Tx buffer size
   //; Console Rx Ring Buffer control
byte   Rx_HeadC;
byte   Rx_TailC;
   //; Console Tx Ring Buffer control
byte   Tx_HeadC;
byte   Tx_TailC;
byte   Tx_BaseC[TxCQsize];
   // Console Rx buffer
byte   Rx_BaseC[RxCQsize];
void console_putc(char TxChar)
; Subroutine console_putc
;   Stdout routine (BLOCKING) for putting characters to the console interface.
; On Exit:
   long counter = 65535;   // setup counter to prevent lockup on failure of USB
   //; test to determine if the USB device is active
   if (!bit_test(USB_PwrEn))
      while ((counter!=0) && bit_test(USB_WRF))
         counter--;
      if (Counter)
         DBus = TxChar;      //; write the character to the data bus
         bit_set(USB_WR);
         DBusDir = 0;      //; set data bus to output
         bit_clear(USB_WR);
         DBusDir = 0xff;      //; set data bus to input
         // timeout waiting on USB
         // .. do something else here such as write to serial port
         putc(TxChar);
      //; USB port not active, do something else like pass control to the async port code
      putc(TxChar);
bit console_kbhit(void)
   // test to determine if the USB device is active
   return ((!bit_test(USB_PwrEn)) && (!bit_test(USB_RDF)));
char console_getc(void)
   char Rx_Char = 0x00;
   // if not active pass exit
   if ((!bit_test(USB_PwrEn)) && (!bit_test(USB_RDF)))
      //  here we have a character in the USB controller
      DBusDir = 0xFF;      // set the data bus to input
      bit_clear(USB_RD);
      Rx_Char = DBus;
      bit_set(USB_RD);
   return (Rx_Char);
   init_pic();
   //; initialise the I/O lines to the USB controller
   bit_set(USB_FLUSH);   //; initialise the flush FIFO pin
   bit_clear(USB_WR);     //; set default WR level
   bit_set(USB_RD);      //; set default RD level
   //; initialise Console receive buffer pointers
   Rx_HeadC = 0;
   Rx_TailC = 0;
   //; initialise Console transmit buffer pointers
   Tx_HeadC = 0;
   Tx_TailC = 0;
   printf(console_putc,"Hello, world\r\n");
   //ExecLoop
   while (1)
      // do something
      // don't forget to scan the USB device
      // note that the FTDI245 has a large input buffer
      // there is not need to do a buffer to buffer copy
Have fun....
alexz
PostPosted: Thu Oct 14, 2004 7:28 am     Reply with quote
Has anybode got a code for the USBN9603
Alex
Mark
PostPosted: Thu Oct 14, 2004 8:16 am     Reply with quote
Like I said, CCS gives it to you:
////                      usbn960x.c                                 ////
////    National USBN960x Hardware layer for CCS's PIC USB driver.   ////
//// This file is part of CCS's PIC USB driver code, which includes: ////
////   usb_desc_*.h - an example set of config and device descriptor ////
////   usb.c - USB token and request handler code                    ////
////   usb.h - definitions, prototypes and global variables          ////
//// usbn960x.c is the hardware layer level driver for the CCS PIC   ////
//// USB driver.  You can replace usbn960x.c with another hardware   ////
//// layer level and still use the other parts of the PIC USB        ////
//// driver.                                                         ////
//// Three examples are given using CCS's PIC USB driver.            ////
//// ex_usb_scope.c is a bulk device that sends 512 bytes to the     ////
//// host and uses the USBN960x.  ex_usb_hid.c is a HID device and   ////
//// uses the PIC16C7x5 or USBN960x.  ex_usb_mouse.c is a HID mouse  ////
//// and uses the PIC16C7x5 or USBN960x.                             ////
//// This example USB peripheral layer was written and tested with   ////
//// CCS's USB Full Speed demo board.  When using your own design,   ////
//// either wire your USB960x the same as our demo board or change   ////
//// the port and pin definitions below.                             ////
////   *************************  NOTE  **************************   ////
//// This driver uses INT_EXT.  It requires INT_EXT to interrupt the ////
//// PIC when an event has happened on the USBN960x.  Because of     ////
//// this code enables interrupts.  A user modification can be made  ////
//// to poll the USBN960x device instead of relying on an interrupt. ////
alexz
PostPosted: Thu Oct 14, 2004 8:21 am     Reply with quote
Yeah, I ve found it now, thanks
Alex
PostPosted: Mon Oct 18, 2004 8:31 am     Reply with quote
http://www.beyondlogic.org/usbnutshell/usb1.htm
http://www.beyondlogic.org/usbnutshell/usb7.htm#PIC16F876Example
Maybe some useful extra information.
