DROLLEMAN Guest
CAN BUS MESSAGES |
Posted: Tue Aug 24, 2004 11:56 am |
I'm starting a new project that requires to connect to the GM 6.0L can bus. Has anyone got the message list or any other detail info on this?
Thx |
iso9001
Posted: Tue Aug 24, 2004 3:58 pm |
Yea... Good luck on that.
Those codes are not impossible to find... In fact, I found one for the J1850 bus today. But I highly doubt anyone will have the codes... and if they do I sort of doubt they'll just hand them over.
However, you're in luck using CAN. J1850 while older and more widespread has very few options for prototyping.
I'll keep checking back here, since this interests me. |
Yashu
Re: CAN BUS MESSAGES |
Posted: Tue Aug 24, 2004 8:43 pm |
DROLLEMAN wrote: | I'm starting a new project that requires to connect to the GM 6.0L can bus. Has anyone got the message list or any other detail info on this?
Thx |
ref SAE HS3000 -or- J1850/J1979 |
iso9001+ Guest
Posted: Wed Aug 25, 2004 2:03 am |
Dont bother reading anything about J1850.
... Those references will give you the physical aspects, but for codes...
well, it depends on what you are looking for. Its its 1 particular code say like the rpm signal, I would unplug all the other moduals from the truck, and set your CAN interface to start picking up signals...
I'm not 100% sure about the CAN syntax, but it should be a start of frame pulse then the header or priority byte(s)... Start pulling only frames of X header, and narrow the work down like that...
Like I said before, I highly doubt anyone will give you codes... The ones I've pulled from J1850 took alot of work and I wouldn't be so fast just to hand them out, |
