Header files gone bad
Mark
PostPosted: Wed Aug 11, 2004 2:54 pm     Reply with quote
My turn to gripe Smile
3.191
#define ADC_OFF                0          // ADC Off
#define ADC_CLOCK_DIV_2        1
#define ADC_CLOCK_DIV_8     0x41
#define ADC_CLOCK_DIV_32    0x81
#define ADC_CLOCK_INTERNAL  0xc1              // Internal 2-6us
Now 3.206
#define ADC_CLOCK_DIV_2    0x100
#define ADC_CLOCK_DIV_8     0x40
#define ADC_CLOCK_DIV_32    0x80
#define ADC_CLOCK_INTERNAL  0xc0          // Internal 2-6us
Now why did they change the constants? It keeps the ADC off!
Mark
Switches and Bank Selects
PostPosted: Wed Aug 11, 2004 2:57 pm     Reply with quote
Optimization 7
....................     case 0b010000000:
....................       StationType = SYRS8;
0BA9:  MOVLW  08
0BAA:  BSF    03.5
0BAB:  MOVWF  5E
....................       StationFlags.IR_Enable = TRUE;
0BAC:  BCF    03.5
0BAD:  BSF    43.6
....................       break;
0BAE:  BSF    03.5
0BAF:  GOTO   3B9
....................     case 0x000000000:
....................       StationType = SYRS9;
0BB0:  MOVLW  09
0BB1:  BSF    03.5
0BB2:  MOVWF  5E
0BB3:  GOTO   3B9
0BB4:  BCF    03.5
....................     default:
....................       StationType = SYRSUNDEFINED;
0BB5:  BSF    03.5
0BB6:  CLRF   5E
0BB7:  GOTO   3B9
0BB8:  BCF    03.5
....................   // If we have an invalid station type then Set_LED_Mode will set the error
....................   Set_LED_Mode(MODE_NORMAL);
0BB9:  CLRF   28
0BBA:  BTFSC  0B.7
0BBB:  BSF    28.7
0BBC:  BCF    0B.7
0BBD:  BSF    03.5
0BBE:  BSF    03.6
0BBF:  CLRF   5C
0BC0:  BCF    0A.3
0BC1:  BCF    03.5
0BC2:  BCF    03.6
0BC3:  CALL   192
0BC4:  BSF    0A.3
0BC5:  BTFSC  28.7
0BC6:  BSF    0B.7
all the goto's should be going to the
0BB8:  BCF    03.5
Opt @ 9
....................     case 0b101000000:
....................       StationType = SYRS7;
0B26:  MOVLW  07
0B27:  BSF    03.5
0B28:  MOVWF  5E
0B29:  GOTO   339
0B2A:  MOVLW  08
0B2B:  BSF    03.5
0B2C:  MOVWF  5E
0B2D:  BCF    03.5
0B2E:  BSF    43.6
0B2F:  BSF    03.5
0B30:  GOTO   339
0B31:  MOVLW  09
0B32:  BSF    03.5
0B33:  MOVWF  5E
0B34:  GOTO   339
0B35:  BSF    03.6
0B36:  BCF    03.6
0B37:  CLRF   5E
0B38:  GOTO   339
0B39:  BCF    03.5
0B3A:  CLRF   28
0B3B:  BTFSC  0B.7
0B3C:  BSF    28.7
0B3D:  BCF    0B.7
0B3E:  BSF    03.5
0B3F:  BSF    03.6
0B40:  CLRF   5C
0B41:  BCF    0A.3
0B42:  BCF    03.5
0B43:  BCF    03.6
0B44:  CALL   17D
0B45:  BSF    0A.3
0B46:  BTFSC  28.7
0B47:  BSF    0B.7
Now the bank selection is correct!
valemike
PostPosted: Wed Aug 11, 2004 3:45 pm     Reply with quote
I never pay attention to optimization levels, though I think I should start!
I use the PCHW at work on this contract i'm on, so i can change optimization levels. But what 2 months from now, I am stuck using my PCH license.
What optimization level does PCH use?
I learn more and more each day not to even tinker with anything that says 3.2X
Sticking with 3.191 and below will help you to perform your core competency - and that's to develop a product for your company. Tinkering with the later versions will turn you into a paying fulltime Beta tester. Shocked Rolling Eyes
I wouldn't dare hook up 3.2XX to a circuit that drives high voltage motors Shocked
Mark
PostPosted: Wed Aug 11, 2004 5:52 pm     Reply with quote
Hardware guy choose MLF package so I am back to the 16F876A instead of the 18F252. I have been using the C18 for the 18's since the early days of the PCH compiler. Before that, all of my 16's are usings something like 2.709. It worked fine for me so I stuck with it even though I continue to pay the maintenance. I wish they would come out with module level compilation.
PostPosted: Wed Aug 11, 2004 11:36 pm     Reply with quote
I don't see a linker as a big deal. Other than working more cleanly
with MPLAB 6.xx, I don't see that the lack of a linker causes any
problems with me completing a project efficiently. We are still feeling
the effects of the vs. 3.2xx changes. I would prefer to let those
changes settle out before any new ones are made.
Mark
PostPosted: Thu Aug 12, 2004 6:21 am     Reply with quote
If you stick to CCS and only CCS then I would agree that the "single source" approach isn't all that bad. But reusing code, using code across microcontrollers, libraries, RTOS's would be better if they had a "real" linker.
