Mark
Header files gone bad |
Posted: Wed Aug 11, 2004 2:54 pm |
My turn to gripe
3.191
#define ADC_OFF 0 // ADC Off
#define ADC_CLOCK_DIV_2 1
#define ADC_CLOCK_DIV_8 0x41
#define ADC_CLOCK_DIV_32 0x81
#define ADC_CLOCK_INTERNAL 0xc1 // Internal 2-6us
Now 3.206
#define ADC_CLOCK_DIV_2 0x100
#define ADC_CLOCK_DIV_8 0x40
#define ADC_CLOCK_DIV_32 0x80
#define ADC_CLOCK_INTERNAL 0xc0 // Internal 2-6us
Now why did they change the constants? It keeps the ADC off! |
Mark
Switches and Bank Selects |
Posted: Wed Aug 11, 2004 2:57 pm |
Optimization 7
.................... case 0b010000000:
.................... StationType = SYRS8;
0BA9: MOVLW 08
0BAA: BSF 03.5
0BAB: MOVWF 5E
.................... StationFlags.IR_Enable = TRUE;
0BAC: BCF 03.5
0BAD: BSF 43.6
.................... break;
0BAE: BSF 03.5
0BAF: GOTO 3B9
.................... case 0x000000000:
.................... StationType = SYRS9;
0BB0: MOVLW 09
0BB1: BSF 03.5
0BB2: MOVWF 5E
0BB3: GOTO 3B9
0BB4: BCF 03.5
.................... default:
.................... StationType = SYRSUNDEFINED;
0BB5: BSF 03.5
0BB6: CLRF 5E
0BB7: GOTO 3B9
0BB8: BCF 03.5
.................... // If we have an invalid station type then Set_LED_Mode will set the error
.................... Set_LED_Mode(MODE_NORMAL);
0BB9: CLRF 28
0BBA: BTFSC 0B.7
0BBB: BSF 28.7
0BBC: BCF 0B.7
0BBD: BSF 03.5
0BBE: BSF 03.6
0BBF: CLRF 5C
0BC0: BCF 0A.3
0BC1: BCF 03.5
0BC2: BCF 03.6
0BC3: CALL 192
0BC4: BSF 0A.3
0BC5: BTFSC 28.7
0BC6: BSF 0B.7
all the goto's should be going to the
Opt @ 9
.................... case 0b101000000:
.................... StationType = SYRS7;
0B26: MOVLW 07
0B27: BSF 03.5
0B28: MOVWF 5E
0B29: GOTO 339
0B2A: MOVLW 08
0B2B: BSF 03.5
0B2C: MOVWF 5E
0B2D: BCF 03.5
0B2E: BSF 43.6
0B2F: BSF 03.5
0B30: GOTO 339
0B31: MOVLW 09
0B32: BSF 03.5
0B33: MOVWF 5E
0B34: GOTO 339
0B35: BSF 03.6
0B36: BCF 03.6
0B37: CLRF 5E
0B38: GOTO 339
0B39: BCF 03.5
0B3A: CLRF 28
0B3B: BTFSC 0B.7
0B3C: BSF 28.7
0B3D: BCF 0B.7
0B3E: BSF 03.5
0B3F: BSF 03.6
0B40: CLRF 5C
0B41: BCF 0A.3
0B42: BCF 03.5
0B43: BCF 03.6
0B44: CALL 17D
0B45: BSF 0A.3
0B46: BTFSC 28.7
0B47: BSF 0B.7
Now the bank selection is correct! |
valemike Guest
Posted: Wed Aug 11, 2004 3:45 pm |
I never pay attention to optimization levels, though I think I should start!
I use the PCHW at work on this contract i'm on, so i can change optimization levels. But what 2 months from now, I am stuck using my PCH license.
What optimization level does PCH use?
I learn more and more each day not to even tinker with anything that says 3.2X
Sticking with 3.191 and below will help you to perform your core competency - and that's to develop a product for your company. Tinkering with the later versions will turn you into a paying fulltime Beta tester.
I wouldn't dare hook up 3.2XX to a circuit that drives high voltage motors  |
Mark
Posted: Wed Aug 11, 2004 5:52 pm |
Hardware guy choose MLF package so I am back to the 16F876A instead of the 18F252. I have been using the C18 for the 18's since the early days of the PCH compiler. Before that, all of my 16's are usings something like 2.709. It worked fine for me so I stuck with it even though I continue to pay the maintenance. I wish they would come out with module level compilation. |
Posted: Wed Aug 11, 2004 11:36 pm |
Quote: | I wish they would come out with module level compilation. | I don't see a linker as a big deal. Other than working more cleanly
with MPLAB 6.xx, I don't see that the lack of a linker causes any
problems with me completing a project efficiently. We are still feeling
the effects of the vs. 3.2xx changes. I would prefer to let those
changes settle out before any new ones are made. |
Mark
Posted: Thu Aug 12, 2004 6:21 am |
If you stick to CCS and only CCS then I would agree that the "single source" approach isn't all that bad. But reusing code, using code across microcontrollers, libraries, RTOS's would be better if they had a "real" linker. |
