Cable assembly to go from .1mm header to ICD-2?
MikeValencia
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Fri Aug 06, 2004 11:12 am     Reply with quote
Does anyone know if there are cable assemblies sold that have on one end, RJ45 connector, and on the other end, a female receptacle that would connect onto the 5(or 6) pins on a board for ICSP?
I would like to buy a nice clean one, so I don't have to spend money on crimpers.
Thanks,
Mike
PostPosted: Fri Aug 06, 2004 12:07 pm     Reply with quote
Do you really mean .1mm or do you mean .1 inch ?
See this post for an explanation of how I adapted the ICD2
cable to a .1 inch header receptacle. I did use a crimping tool
to attach the contacts for the Molex KK receptacle to 6 wires.
We have that tool because we use those connectors so much.
But any cheap multi-purpose crimper will do it, too.
http://www.ccsinfo.com/forum/viewtopic.php?t=19157
Mark
PostPosted: Fri Aug 06, 2004 12:22 pm     Reply with quote
how about just doing up a small PCB that has an RJ11 6 pos connected to a female socket.
MikeValencia
PostPosted: Fri Aug 06, 2004 12:49 pm     Reply with quote
Yeah, looks like i'll do something like what Mark mentioned through the weekend.
PCM's link will be helpful, especially since the Digikey part numbers are mentioned!
Charlie U
PostPosted: Sat Aug 07, 2004 9:22 am     Reply with quote
Melabs has an adapter that I have been using successfully with the ICD-U40. It is a small pcb (as mentioned above) with an RJ-11 and a 10 pin header. It comes with a 10 pin cable as well. You would have to put a header on you target board with the correct pin out. This is shown in the schematic for the lab x-1 proto board. It's $19.95.
[url]
http://www.melabs.com/products/accessry.htm
[/url]
Mark
PostPosted: Sat Aug 07, 2004 9:41 am     Reply with quote
I just use cut the end off the ICD cable and then put a different connector on there. Of course it does require a crimper but that is not a problem for me.
