DS1616 temperature
bubbi
DS1616 temperature
PostPosted: Sat Jul 10, 2004 11:51 am     Reply with quote
Hi there,
I can't read the temperature out of this IC.
My functions always return 0.
Can anyone give me a hint?
My code:
#include "TempLogger.h"
#define TMP_SCLK PIN_B1
#define TMP_IO   PIN_B3
#define TMP_RST  PIN_B2
BYTE temperatur=0;
char c;
BYTE read_ds1616(BYTE cmd) {
   BYTE i,data;
   output_high(TMP_RST);
   write_ds1616_byte(cmd);
   for(i=0;i<=7;++i) {
      shift_right(&data,1,input(TMP_IO));
      output_high(TMP_SCLK);
      delay_us(2);
      output_low(TMP_SCLK);
      delay_us(2);
   output_low(TMP_RST);
   return(data);
BYTE TMP_get_temp() {
   BYTE temp;
   temp = read_ds1616(0x55);      // Get Temperature
   return(temp);
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_counters(RTCC_INTERNAL,RTCC_DIV_1);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
      zeichen=getch();
      if (c=='2') {
         printf("HiThere\n\r");
      if (c=='1') {
         temperatur=TMP_get_temp();
         printf("temp: %i\n\r",temperatur);  //output RS232
PostPosted: Sun Jul 11, 2004 9:53 pm     Reply with quote
Look at the source code posted on this page:
http://sjeffroy.free.fr/GBF_num_/DS1615_-_DS1616/ds1615_-_ds1616.html
Especially look at the code for this function:
ds1616_temp()
Notice he is doing two things that you are not doing:
1. He tests the CS0 bit in the Control 2 register. If the CS0 bit
is not = 1, then he sets it = 1.
2. He sends the command (0x55) to read the temperature.
But before he reads the temperature value, he checks the DR
bit in the Status 1 register. When DR = 1, then he reads the
temperature.
If you make these two changes to your code, it will probably work.
bubbi
PostPosted: Mon Jul 12, 2004 4:04 am     Reply with quote
Thanks !!!
This page helps me a lot
