bubbi Guest
| DS1616 temperature |
Posted: Sat Jul 10, 2004 11:51 am |
Hi there,
I can't read the temperature out of this IC.
My functions always return 0.
Can anyone give me a hint?
My code:
#include "TempLogger.h"
#define TMP_SCLK PIN_B1
#define TMP_IO PIN_B3
#define TMP_RST PIN_B2
BYTE temperatur=0;
char c;
BYTE read_ds1616(BYTE cmd) {
BYTE i,data;
output_high(TMP_RST);
write_ds1616_byte(cmd);
for(i=0;i<=7;++i) {
shift_right(&data,1,input(TMP_IO));
output_high(TMP_SCLK);
delay_us(2);
output_low(TMP_SCLK);
delay_us(2);
output_low(TMP_RST);
return(data);
BYTE TMP_get_temp() {
BYTE temp;
temp = read_ds1616(0x55); // Get Temperature
return(temp);
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_counters(RTCC_INTERNAL,RTCC_DIV_1);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
zeichen=getch();
if (c=='2') {
printf("HiThere\n\r");
if (c=='1') {
temperatur=TMP_get_temp();
printf("temp: %i\n\r",temperatur); //output RS232
Posted: Sun Jul 11, 2004 9:53 pm |
Look at the source code posted on this page:
http://sjeffroy.free.fr/GBF_num_/DS1615_-_DS1616/ds1615_-_ds1616.html
Especially look at the code for this function:
ds1616_temp()
Notice he is doing two things that you are not doing:
1. He tests the CS0 bit in the Control 2 register. If the CS0 bit
is not = 1, then he sets it = 1.
2. He sends the command (0x55) to read the temperature.
But before he reads the temperature value, he checks the DR
bit in the Status 1 register. When DR = 1, then he reads the
temperature.
If you make these two changes to your code, it will probably work.
bubbi Guest
Posted: Mon Jul 12, 2004 4:04 am |
Thanks !!!
This page helps me a lot |
