PCWH IDE "Options|Global defines" Load & Save
kypec
PostPosted: Thu Jun 17, 2004 5:53 am     Reply with quote
is there anyone who can help me with this problem?
I'm using PCWH IDE and I like the option Global Defines.
I know how to use it and what is it meant for.
I can also SAVE my settings to a file (clicking the Save button).
However, whenever I want to LOAD my settings from the file
which I saved before, there is no file visible in a dialog box.
There can be only selected File type as "Global Defines"
but WHAT EXTENSION THESE FILE IS SUPPOSED TO HAVE??? Evil or Very Mad
My version numbers are as follows:
IDE 3.43
PCB=PCM=PCH 3.190
TIA,
kypec
Neutone
PostPosted: Thu Jun 17, 2004 6:51 am     Reply with quote
You are saving source code. Use the extention '.c'
kypec
PostPosted: Thu Jun 17, 2004 7:36 am     Reply with quote
Neutone, have you tried yourself what you have suggested as
a solution Question
Because for me, none of these extensions has worked i.e. appeared
in the dialog box:
".c"
".h"
".txt"
Crying or Very sad
I have a strong feeling that it may be some bug in PCWH IDE...
Neutone
PostPosted: Thu Jun 17, 2004 7:50 am     Reply with quote
You are correct you don't have to add the extention. It is placed there automaticly. Simply specify a name. I have never had a problem.
