kypec
| PCWH IDE "Options|Global defines" Load & Save |
Posted: Thu Jun 17, 2004 5:53 am |
is there anyone who can help me with this problem?
I'm using PCWH IDE and I like the option Global Defines.
I know how to use it and what is it meant for.
I can also SAVE my settings to a file (clicking the Save button).
However, whenever I want to LOAD my settings from the file
which I saved before, there is no file visible in a dialog box.
There can be only selected File type as "Global Defines"
but WHAT EXTENSION THESE FILE IS SUPPOSED TO HAVE???
My version numbers are as follows:
IDE 3.43
PCB=PCM=PCH 3.190
TIA,
kypec |
Neutone
Posted: Thu Jun 17, 2004 6:51 am |
| You are saving source code. Use the extention '.c' |
kypec
Posted: Thu Jun 17, 2004 7:36 am |
Neutone, have you tried yourself what you have suggested as
a solution
Because for me, none of these extensions has worked i.e. appeared
in the dialog box:
".c"
".h"
".txt"
I have a strong feeling that it may be some bug in PCWH IDE... |
Neutone
Posted: Thu Jun 17, 2004 7:50 am |
| You are correct you don't have to add the extention. It is placed there automaticly. Simply specify a name. I have never had a problem. |
