asjad
Joined: 09 Mar 2004 Posts: 52 Location: Greater Manchester - UK
| NEED HELP, PLEASE!! - FUNCTION NOT BEEN CALLED |
Posted: Sun May 23, 2004 9:36 am |
MPLAB 6.5
PCM V 3.186
MPLAB ICD2
Dear All,
I am in a rut can someone help me please!!!
I HAVE CODED A SIMPLE CLOCK PROGRAM, ThE ACTUAL INCREMENTATION of mins/hours/milli WORKS PERFECT
BUT WHEN I TRY TO CALL THE DISPLAY FUNCTION WITHIN THE ISR() it simply ignores the call
NO COMPILER ERRORS!!!!!!!!
code =
#if defined(__PCM__)
#include <16F874.h>
#device ICD=TRUE
#fuses XT,NOWDT,NOPROTECT,NOLVP,PUT,NOBROWNOUT
#include <lcd.c>
void display(void);
#bit t0if = 0xb.2
int sec=0; //second
int min=0;//minute
int hrs=0; //hour
int milli=0;
int increment = 0;
char data[16];
#int_rtcc
void clock()
increment++;
if (increment==2)
{ milli++;
increment=0;
if (milli==10) // 10*100ms = 1second passed
sec++;
milli=0;
if (sec==60) // 60*1sec = minute
sec=0;
min++;
display();
if (min==60)
min=0;
hrs++;
display(); THIS FUNCTION WILL NOT CALL
if ((hrs==24) || (hrs && min==0))
sec=0;
hrs=0;
display(); //THIS FUNCTION WILL NOT CALL
if (milli < 10) //milli lower than 10 exit after incrementing milli
set_RTCC(60); //setup TMR0 to count upto 100ms
void display(void)
if (t0if==TRUE)
lcd_gotoxy(0,1);
printf(lcd_putc,"%02U:%02U",hrs,min);
lcd_gotoxy(1,1);
printf(lcd_putc,"%S",data);
enable_interrupts(int_RTCC);
setup_counters(RTCC_INTERNAL,RTCC_DIV_256);
set_RTCC(60);
} _________________ Best Regards |
future
Posted: Sun May 23, 2004 11:02 am |
| Try to set a flag in ISR and in main loop call this LCD function. |
asjad
| Clarifying the question question |
Posted: Sun May 23, 2004 11:03 am |
The function of the code is a "real time clock"
Within the ISR I call a function called "display()", this function updates the time on the LCD using the standard CCS drivers.
When I step throught the code the system seems to ignore the call to the display function all together.
The ISR is working as I can see the variables min, hour, milli being incremented as a real time clock.
NO COMPILER ERRORS
I thankyou in advance for advising me! _________________ Best Regards |
asjad
| function will not be called even from the |
Posted: Sun May 23, 2004 11:11 am |
If I try to call the fucntion from function main, it will still not branch
Is the compiler version bug free? _________________ Best Regards |
rwyoung
Joined: 12 Nov 2003 Posts: 563 Location: Lawrence, KS USA
Posted: Sun May 23, 2004 11:14 am |
You should not call code like "printf" from inside ISRs. Two reasons, one is it takes too long to execute and second is that printf is not re-entrant.
Set a flag inside your ISR indicating there is new data to print or keep a phantom copy outside the ISR and test for new data in your main.
int1 newdata;
newdata=0; // initialize boolean flag
// your initialization routines here to set up timer, etc
if (newdata)
display();
newdata=0; // clear new data flag
// do other things in you main or just let it run a
// tight loop looking for new data to display...
#int_rtcc
void clock()
if (!newdata) // use this to block changes to data structure during
{ // display(). otherwise just run your code
// your code goes here
newdata=1; // signal new data ready
_________________ Rob Young
The Screw-Up Fairy may just visit you but he has crashed on my couch for the last month! |
| Re: Clarifying the question question |
| asjad wrote: | The function of the code is a "real time clock"
NO COMPILER ERRORS
I thankyou in advance for advising me! |
As the previous reply:
DO NOT call your LCD function from inside of the ISR.
Make a global flag
int flag=0;
the in the ISR set it to 1
and somwwhere in your main loop test the flag and then call the LCD function
somewhere in main loop
if ( flag == 1 )
LCD();
flag=0; // allow it to be called again
