NEED HELP, PLEASE!! - FUNCTION NOT BEEN CALLED
asjad
PostPosted: Sun May 23, 2004 9:36 am     Reply with quote
MPLAB 6.5
PCM V 3.186
MPLAB ICD2
Dear All,
I am in a rut can someone help me please!!!
I HAVE CODED A SIMPLE CLOCK PROGRAM, ThE ACTUAL INCREMENTATION of mins/hours/milli WORKS PERFECT
BUT WHEN I TRY TO CALL THE DISPLAY FUNCTION WITHIN THE ISR() it simply ignores the call
NO COMPILER ERRORS!!!!!!!!
code =
#if defined(__PCM__)
#include <16F874.h>
#device ICD=TRUE
#fuses XT,NOWDT,NOPROTECT,NOLVP,PUT,NOBROWNOUT
#endif
#include <lcd.c>
void display(void);
#bit t0if = 0xb.2
int sec=0; //second
int min=0;//minute
int hrs=0; //hour
int milli=0;
int increment = 0;
char data[16];
#int_rtcc
void clock()
increment++;
if (increment==2)
{ milli++;
increment=0;
if (milli==10) // 10*100ms = 1second passed
sec++;
milli=0;
if (sec==60) // 60*1sec = minute
sec=0;
min++;
display();
if (min==60)
min=0;
hrs++;
display(); THIS FUNCTION WILL NOT CALL
if ((hrs==24) || (hrs && min==0))
sec=0;
hrs=0;
display(); //THIS FUNCTION WILL NOT CALL
if (milli < 10) //milli lower than 10 exit after incrementing milli
set_RTCC(60); //setup TMR0 to count upto 100ms
void display(void)
if (t0if==TRUE)
lcd_gotoxy(0,1);
printf(lcd_putc,"%02U:%02U",hrs,min);
lcd_gotoxy(1,1);
printf(lcd_putc,"%S",data);
enable_interrupts(int_RTCC);
setup_counters(RTCC_INTERNAL,RTCC_DIV_256);
set_RTCC(60);
Best Regards
future
PostPosted: Sun May 23, 2004 11:02 am     Reply with quote
Try to set a flag in ISR and in main loop call this LCD function.
asjad
Clarifying the question question
PostPosted: Sun May 23, 2004 11:03 am     Reply with quote
The function of the code is a "real time clock"
Within the ISR I call a function called "display()", this function updates the time on the LCD using the standard CCS drivers.
When I step throught the code the system seems to ignore the call to the display function all together.
The ISR is working as I can see the variables min, hour, milli being incremented as a real time clock.
NO COMPILER ERRORS
I thankyou in advance for advising me!
Best Regards
asjad
function will not be called even from the
PostPosted: Sun May 23, 2004 11:11 am     Reply with quote
If I try to call the fucntion from function main, it will still not branch
Is the compiler version bug free?
Best Regards
rwyoung
PostPosted: Sun May 23, 2004 11:14 am     Reply with quote
You should not call code like "printf" from inside ISRs. Two reasons, one is it takes too long to execute and second is that printf is not re-entrant.
Set a flag inside your ISR indicating there is new data to print or keep a phantom copy outside the ISR and test for new data in your main.
int1 newdata;
   newdata=0; // initialize boolean flag
   // your initialization routines here to set up timer, etc
      if (newdata)
         display();
         newdata=0; // clear new data flag
      // do other things in you main or just let it run a
      // tight loop looking for new data to display...
#int_rtcc
void clock()
   if (!newdata) // use this to block changes to data structure during
   {                 // display().  otherwise just run your code
      // your code goes here
   newdata=1; // signal new data ready
Rob Young
Re: Clarifying the question question
NO COMPILER ERRORS
As the previous reply:
DO NOT call your LCD function from inside of the ISR.
Make a global flag
int flag=0;
the in the ISR set it to 1
and somwwhere in your main loop test the flag and then call the LCD function
somewhere in main loop
if ( flag == 1 )
LCD();
flag=0; // allow it to be called again
