Haplo
Joined: 06 Sep 2003 Posts: 659 Location: Sydney, Australia
| Voltage Regulator... |
Posted: Tue May 18, 2004 4:10 am |
| Can anybody please recommend a linear low-drop 5V 2A voltage regulator (TO220)? Thanks. |
rwyoung
Posted: Tue May 18, 2004 7:21 am |
Possible choices are:
Linear Technology - LT1528, LT1529 & LT1764/A however I don't believe these are available as TO-220 packages. Drop-out voltage ranges from 600mV down to 340mV, 3A output current
National Semicondutor - LP3856, LP3876, LP3966, LP3853, LP3873 and some others.
I'd suggest you prowl around on Linear Tech's site, National Semiconductor's site, On-Semiconductor (Motoroloa) and Micrel. You have lots of choices based on quiescent current, drop-out (the term "Low Drop Out" is a relative thing), input voltage range, temp rating and pin-outs. _________________ Rob Young
wojc0008
| National Semiconductor |
Posted: Tue May 18, 2004 7:30 am |
| If you need a demoboard let me know. I work for National. |
Humberto
Posted: Tue May 18, 2004 7:35 am |
KD1084 Series from ST Microelectronics
5V Low Drop (1.5V max)
Guaranteed output current up to 5A
Package TO220
HTH,
Humberto |
RatFink
| Re: National Semiconductor |
Posted: Tue May 18, 2004 9:46 am |
| wojc0008 wrote: | | If you need a demoboard let me know. I work for National. |
OOOH, this is off topic, but can you tell me if National has an IC temp sensor that's rated for more than 300 deg Farenheit? In some of their paperwork I've seen them mentioned, but I can't find any for sell. |
Haplo
Posted: Tue May 18, 2004 5:28 pm |
| Thanks everyone for your inputs. Sometimes simple things like this can waste so much time... |
wojc0008
SherpaDoug
| High temp sensors |
Posted: Wed May 19, 2004 9:22 am |
Above 300F you may have to go to platinum RTDs (not as expensive as it sounds) or thermocouples. It is just hard to package a silicon chip for those temperatures! _________________ The search for better is endless. Instead simply find very good and get the job done. |
