Is the code correct?
Thanks in advance.
Sorry for my bad english.
Change ulong to int32 and uchar to int8. It helps to keep things straight when changing between compilers.
dyeatman
UChar Problems
Posted: Wed Apr 07, 2004 10:06 am
This compiler is not an embeedded compiler and not a full blown C compiler so there are differences in the syntax.
The CCS C manual page 64 covers all the valid data types and the entire sections on Data Types and Function Definitions should be read to better understand the limitations.
