Uchar problems
Franz
Uchar problems
PostPosted: Wed Apr 07, 2004 9:29 am     Reply with quote
Hello I have a problems.
If I write:
void tipol ( ulong misura, uchar offset )
uchar var ;
var = 0xff&(misura >> 24) ;
Can i do it in a uchar?
Is the code correct?
Thanks in advance.
Sorry for my bad english.
Question
Neutone
Re: Uchar problems
PostPosted: Wed Apr 07, 2004 9:41 am     Reply with quote
If I write:
uchar var ;
Thanks in advance.
Question
Change ulong to int32 and uchar to int8. It helps to keep things straight when changing between compilers.
UChar Problems
PostPosted: Wed Apr 07, 2004 10:06 am     Reply with quote
This compiler is not an embeedded compiler and not a full blown C compiler so there are differences in the syntax.
The CCS C manual page 64 covers all the valid data types and the entire sections on Data Types and Function Definitions should be read to better understand the limitations.
