micro
| 18f452 clock problem |
Posted: Fri Feb 20, 2004 8:14 am |
I am using PIC18F452 with 40MHz externat XTAL osc. I wrote a code that has spi port configurations and application. But when I listen to SCLK pin, I see approx 3MHz clock frequency..This is the first time using this series. Before, I used 16f8xx series. My code snipped is below. Could give me any advise about the problem.. Thanks..
#include <16f877.h>
#device *=16
#use standard_io(B)
#use rs232 (baud=9600, xmit=PIN_C6, rcv=PIN_C7,ERRORS)
#use standard_io(A)
#use standard_io(D)
int32 count;
int16 time=0xFFF8;
int pn=0;
output_high(LED1);
setup_adc(ADC_OFF);
setup_adc_ports(NO_ANALOGS);
setup_psp(PSP_ENABLED);
enable_interrupts(INT_PSP);
setup_spi(spi_master |spi_l_to_h |spi_clk_div_4);
bit_clear(*0x14,4); // ------> CKP
bit_clear(*0x94,6);// ------> CKE
spi_write(0x55);
delay_us(20);
Neutone
Posted: Fri Feb 20, 2004 8:19 am |
I would have guessed closer to 2.5Mhz.
40Mhz crystle = 10 Mhz instruction clock.
Your dividing it by 4
Try a diferent divider. |
micro
Posted: Fri Feb 20, 2004 8:36 am |
I use the code snipped below but it gives error (undefined identifier!)..I think the problem is diffrent.
setup_spi(spi_master |spi_l_to_h |spi_clk_div_1);
Clock division could be minimum spi_clk_div_4. I use same code for 16f877 and 20 MHz external XTAL osc, I see 5 MHz clock on SCLK pin. What the problem is about the 18f452.
With 40 MHz external osc , it must be 10 MHz instruction cycle? İt that is true, when I use setup_spi(spi_master |spi_l_to_h |spi_clk_div_4),
it must be 10 Mhz SPI clock. Musn't it? |
Neutone
Posted: Fri Feb 20, 2004 9:10 am |
Try a divider of 64 or 16
With the exception of when PLL is used the instruction cycles are 1/4 the speed of the crystle. PLL makes it 1 for 1 but is only usable on crystles 10Mhz and lower. It is also only an option on the PIC18 series. |
dvsoft
Posted: Fri Feb 20, 2004 9:12 am |
hello
you use 40Mhz external XTAL?? or 10Mhz Xtal with PLL |
micro
Posted: Fri Feb 20, 2004 9:29 am |
| I am using 40 MHZ external XTAL without PLL. May it a problem? What is the max value for external XTAL using without PLL. ? |
Neutone
Posted: Fri Feb 20, 2004 9:56 am |
Try
setup_spi(SPI_MASTER |SPI_H_TO_L | SPI_CLK_DIV_64 );
It's what I use. |
mvaraujo
Posted: Fri Feb 20, 2004 12:03 pm |
In order to keep lower EMI, i would rather use a 10MHz Xtal and clock multiplied by 4 in hardware. I have a config running like that fine.
My configs and fuses are:
#use delay(clock=40000000) // clock de 40MHz
#fuses H4,NOOSCSEN,NOWDT,PUT,NOPROTECT,NOBROWNOUT,NOSTVREN,NOLVP,NODEBUG // config bits
