printf delays in transmiting buffer
samg
PostPosted: Thu Feb 05, 2004 11:33 pm     Reply with quote
Question
Can anyone tell me what the delay that the compiler uses for when the hardware RS232 buffer is full during transmitting.
I believe that the delay is longer than 15 milliseconds at 9600 baud.
The project uses a 20Mhz clock.
I am working on a project where a delay in the transmitting can cause probelms. I need to have the bytes transmit as fast as possible.
Should I be using putc instead of printf?
PostPosted: Fri Feb 06, 2004 12:03 am     Reply with quote
It doesn't do any delay. You do have to wait until a character
has been transmitted from the hardware UART, which frees up
the TXREG so it can accept the next character. The wait time
required will be:
# of bits/char          10
--------------     =  -------  = 1.04 ms
baud rate              9600
0000                00302 .................... printf("ABCDEFG");
0020 01A1       00303 CLRF   21
0021 0821       00304 MOVF   21,W
0022 2004       00305 CALL   004    // Fetch char from const string
0023 0AA1       00306 INCF   21,F   // Increment the char count
0024 00F7       00307 MOVWF  77
0025 0877       00308 MOVF   77,W
0026 1E0C       00309 BTFSS  0C.4    // Is the transmitter ready ?
0027 2826       00310 GOTO   026     // If not, wait in a tight loop
0028 0099       00311 MOVWF  19      // Then send the char
0029 3007       00312 MOVLW  07      // Get the string length
002A 0221       00313 SUBWF  21,W    // Compare it to # of chars sent
002B 1D03       00314 BTFSS  03.2    // Jump if we're done
002C 2821       00315 GOTO   021  // If not done, jump to top of loop
// This code fetches a char from the const string.
0004  100A  @const  bcf    0xA,0x0
0005  108A          bcf    0xA,0x1
0006  110A          bcf    0xA,0x2
0007  0782          addwf  0x2
0008  3441          retlw  0x41      // 'A'
0009  3442          retlw  0x42      // 'B'
000A  3443          retlw  0x43      // 'C'
000B  3444          retlw  0x44      // 'D'
000C  3445          retlw  0x45      // 'E'
000D  3446          retlw  0x46      // 'F'
000E  3447          retlw  0x47      // 'G'
000F  3400          retlw  0x0
samg
I found my Bug, Thanks
PostPosted: Fri Feb 06, 2004 12:53 am     Reply with quote
Using the C/ASM code like you showed, I found that it was a goof up in the printf I was using.
printf ("\x0F\x34\x00\xF0\x04");
I needed to push out some binary values and was looking for a quick way to push out binary sequences without taking up RAM.
The ASM code will show that the string length is 2 bytes.
The NULL in the center ends the string. (NULLs can't be printed in printf! Duh!)
changed to:
int CONST sequence_1 [5] = {0x0F,0x34,0x00,0xF0,0x04};
for (i=0;i<5;i++) {
putc(sequence_1[i]);
I need to do this because I have a bunch of sequences and
don't want to use up RAM storing them. And I know that
const byte arrays cannot pointed to so a generic function is out.
The above seems the most efficient.
Thanks for the help!
Re: I found my Bug, Thanks
PostPosted: Fri Feb 06, 2004 11:43 am     Reply with quote
changed to:
for (i=0;i<5;i++) {
Worth pointing out that CCS, has a 'shortcut', that may allow you to use a suitable 'generic' function. Any 'putc' type function, that accepts a single integer, can be called using the syntax:
putc("Constant string");
and the function will be called once for each character in the 'Constant string'. This works with your own functions, as well as CCS ones.
