samg
Joined: 05 Feb 2004 Posts: 2 Location: Colorado Springs, CO
| printf delays in transmiting buffer |
Posted: Thu Feb 05, 2004 11:33 pm |
Can anyone tell me what the delay that the compiler uses for when the hardware RS232 buffer is full during transmitting.
I believe that the delay is longer than 15 milliseconds at 9600 baud.
The project uses a 20Mhz clock.
I am working on a project where a delay in the transmitting can cause probelms. I need to have the bytes transmit as fast as possible.
Should I be using putc instead of printf? |
Posted: Fri Feb 06, 2004 12:03 am |
It doesn't do any delay. You do have to wait until a character
has been transmitted from the hardware UART, which frees up
the TXREG so it can accept the next character. The wait time
required will be:
| Code: | # of bits/char 10
-------------- = ------- = 1.04 ms
baud rate 9600 |
| Code: | 0000 00302 .................... printf("ABCDEFG");
0020 01A1 00303 CLRF 21
0021 0821 00304 MOVF 21,W
0022 2004 00305 CALL 004 // Fetch char from const string
0023 0AA1 00306 INCF 21,F // Increment the char count
0024 00F7 00307 MOVWF 77
0025 0877 00308 MOVF 77,W
0026 1E0C 00309 BTFSS 0C.4 // Is the transmitter ready ?
0027 2826 00310 GOTO 026 // If not, wait in a tight loop
0028 0099 00311 MOVWF 19 // Then send the char
0029 3007 00312 MOVLW 07 // Get the string length
002A 0221 00313 SUBWF 21,W // Compare it to # of chars sent
002B 1D03 00314 BTFSS 03.2 // Jump if we're done
002C 2821 00315 GOTO 021 // If not done, jump to top of loop
// This code fetches a char from the const string.
0004 100A @const bcf 0xA,0x0
0005 108A bcf 0xA,0x1
0006 110A bcf 0xA,0x2
0007 0782 addwf 0x2
0008 3441 retlw 0x41 // 'A'
0009 3442 retlw 0x42 // 'B'
000A 3443 retlw 0x43 // 'C'
000B 3444 retlw 0x44 // 'D'
000C 3445 retlw 0x45 // 'E'
000D 3446 retlw 0x46 // 'F'
000E 3447 retlw 0x47 // 'G'
000F 3400 retlw 0x0
samg
| I found my Bug, Thanks |
Posted: Fri Feb 06, 2004 12:53 am |
Using the C/ASM code like you showed, I found that it was a goof up in the printf I was using.
printf ("\x0F\x34\x00\xF0\x04");
I needed to push out some binary values and was looking for a quick way to push out binary sequences without taking up RAM.
The ASM code will show that the string length is 2 bytes.
The NULL in the center ends the string. (NULLs can't be printed in printf! Duh!)
changed to:
int CONST sequence_1 [5] = {0x0F,0x34,0x00,0xF0,0x04};
for (i=0;i<5;i++) {
putc(sequence_1[i]);
I need to do this because I have a bunch of sequences and
don't want to use up RAM storing them. And I know that
const byte arrays cannot pointed to so a generic function is out.
The above seems the most efficient.
Thanks for the help! |
| Re: I found my Bug, Thanks |
Posted: Fri Feb 06, 2004 11:43 am |
| samg wrote: | Using the C/ASM code like you showed, I found that it was a goof up in the printf I was using.
changed to:
for (i=0;i<5;i++) {
Worth pointing out that CCS, has a 'shortcut', that may allow you to use a suitable 'generic' function. Any 'putc' type function, that accepts a single integer, can be called using the syntax:
putc("Constant string");
and the function will be called once for each character in the 'Constant string'. This works with your own functions, as well as CCS ones.
