		| Author | Message |
		| HLDewar Guest
				| New icds.exe bad? |
				|  Posted: Wed Dec 10, 2003 11:44 am |   |
				| Yesterday, I downloaded and installed the latest icds.exe, released on 9-Dec-2003.  After installing it, I could not compile code for the 18F8720.  The compiler justs freezes up.
 I am running
 PCW IDE 3.21
 PCB 3.116
 PCM 3.116
 PCH 3.116
 Is there a problem with the latest icds.exe and my version of the compiler?  Can I get an earlier version of icds.exe?  (I no longer have the icds.exe that I had installed previously.)
 I reinstalled the compiler without installing icds.exe, and when I compile my 18F8720 code, I get an error that it does not recognize something in the #FUSES line.  If I take out some of the fuse settings, I can get it to compile.  But if I then install icds.exe, it stops working again.
 Any suggestions?
		| HLDewar Guest
				| devices.dat |
				|  Posted: Wed Dec 10, 2003 1:24 pm |   |
				| The problem seems to come from the new devices.dat file that gets installed by icds.exe.  I reinstalled the compiler, which works except for the error on unrecognized #FUSE settings.  I reinstalled icds.exe in a separate folder.  If I just copy the new devices.dat file from the ICDS folder to the compiler folder (PICC), the compiler stops working, view valid fuses stops working, view valid interrupts stops working, and the device editor stops working.
  Is there some way to get a previous version of devices.dat or icsd.exe?
 Thank you for any help.
		| Haplo
				|  Posted: Wed Dec 10, 2003 4:29 pm |   |
				| The new icds.exe crashes miserably on my machine, so I'm already back to the old version. |  |
		| Guest
				|  Posted: Wed Dec 10, 2003 5:52 pm |   |
				| I have the old devices.dat, email me if you neen it.
 Pedro_Zamora@msn.com
		| HLDewar Guest
				|  Posted: Wed Dec 10, 2003 9:29 pm |   |
				| In case anyone was wondering, the old devices.dat solved the problem.
 Muchos Gracias, Pedro.
		| ChrisAH
				|  Posted: Wed Dec 24, 2003 12:21 pm |   |
				| I am running the demo version to evaluate the product. I downloaded the Dec 22nd ICDS update, and it locked the compiler up and caused me 1/2 a days messing around trying to fix it. Thankfully I then found this post, and the cure was the same...  use the old devices.dat file.
 My guess is that the devices.dat file aligns with the latest compiler release, which is bearable if you have compiler maintenance.... hmmmmm, only get compiler updates for 30 days if you purchase the product... hmmmm
 Chris
 | You cannot post new topics in this forum You cannot reply to topics in this forum
