SherpaDoug
Trivial string problem |
Posted: Wed Jun 04, 2008 9:24 am |
In years of working with PICs and CCS I have never had to use strings until now. This code is almost verbatim from my beginning C primer. It prints "Hello Small_Strings" and "This is a quoted string" but it prints nothing for globalstring.
What am I doing wrong? Is it some peculiarity of PICs or CCS? I suspect I am not declaring the string correctly.
I am using PCW 3.242 with a PIC18F2585.
Code: | char globalstring[] = "This is a global string.";
output_high(PWR_485);
fprintf(Gliderbus,"Hello Small_Strings\n\r");
while(1){
fprintf(Gliderbus,"This is a Quoted String\n\r");
fprintf(Gliderbus,"%s", globalstring);
Output: Code: | Hello Small_Strings
This is a Quoted S....... |
_________________ The search for better is endless. Instead simply find very good and get the job done. |
Posted: Wed Jun 04, 2008 10:11 am |
I installed vs. 3.242 and ran the following program in MPLAB Simulator.
It works. It displays this in the Output window:
Quote: |
Hello Small_Strings
#include <18F2585.h>
#fuses INTRC_IO, NOWDT, PUT, BROWNOUT, NOLVP, NOPBADEN
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS, stream=Gliderbus)
SherpaDoug
Stranger & stranger... |
Posted: Wed Jun 04, 2008 12:23 pm |
Thanks PCM, but here is my output and the exact code I am now running, mostly your code with minimum changes for my hardware:
Thi |
Code: | #include <18F2585.h>
#fuses HS, NOWDT, PUT, BROWNOUT, NOLVP, NOPBADEN
#use delay(clock=8000000)
#define PWR_485 PIN_C3
#use rs232(baud=1200, xmit=PIN_C6, rcv=PIN_C7, ERRORS, stream=Gliderbus, enable=PIN_B3)
while(1){
I even ran it real slow (600 baud) to see if the global string was being overwritten. How can "Quoted String" print, but "global string" not print? _________________ The search for better is endless. Instead simply find very good and get the job done. |
Posted: Wed Jun 04, 2008 12:57 pm |
There's a problem with using the Enable pin with printf or fprintf in your
version of the compiler. This problem is fixed in later versions.
This thread discusses some work-arounds:
http://www.ccsinfo.com/forum/viewtopic.php?t=28433 |
SherpaDoug
Posted: Wed Jun 04, 2008 1:19 pm |
Wow, thanks! It would have taken me forever to find that. The work around is simple, almost elegant.
It is so good to find it's not pilot error  _________________ The search for better is endless. Instead simply find very good and get the job done. |
