SerialGmr8
| PIC 16F877A interrupt on B4 strange activity |
Posted: Fri May 23, 2008 9:01 am |
Greetings programming gurus.
Im trying to interrupt when a change (hi/low) is detected on PIN B4 on my pic16f877a. My code in entirety is as follows;
#include <16F877a.h>
int8 value = 0;
#INT_RB
void portchange_isr ()
value = input(PIN_B4);
output_low(pin_c5);
enable_interrupts(INT_RB);
set_tris_B(0xF0);
if (value == 0)
output_low(pin_c5);
output_high(pin_c5);
//IDE VERSION 4.057
//PCM VERSION 4.057
//PCB VERSION 4.057
The issue I am having is as follows.
I know that the interrupt routine gets called and executed, however i have PIN_C5 connected to an LED. This LED seems to stay on all the time. I know the interrupt gets called, because when I toggle (with a wire) between 5v and zer0 volts at b4, the led brightens and dims accordingly.
It almost seems like I have a floating issue, but the only wires connected to my chip are grounds and the vcc. Might anyone be able to shed some light on this situation for me ?
Best Regards,
SerialGmr8 |
Posted: Fri May 23, 2008 9:26 am |
As you have it setup, B4, B5, B6, and B7, will all trigger the interrupt. If these are not pulled to a rail, then you will get spurious triggers. Enable the portb pullups on the port, so these pins are all pulled high, before enabling the interrupt, to avoid this.
SerialGmr8
Posted: Fri May 23, 2008 9:48 am |
Thank you Ttelmah. All is well with my code
Regards,
SerialGmr8 |
