ICD-S40 PIC16F877A. Target could not detected
Post new topic   Reply to topic    CCS Forum Index -> CCS ICD / Mach X / Load-n-Go
Surati
PostPosted: Thu Mar 20, 2008 10:34 pm     Reply with quote
I just bought PIC16F877A development Kit. I couldn't run a test target of ICD Control Program. An error message Target could not detected appears. I run the hardware diagnostic, but I failed to read device ID. The error appears " The device ID is not a valid device id for the target chip". I have check cable connection, it's look properly connected. Anyone can help me to solve the problem since I'm new in programming embeded software.
Thanks .
PostPosted: Thu Mar 20, 2008 10:46 pm     Reply with quote
Here is the ICD-S Reference Manual:
http://public.enst-bretagne.fr/~moga/ISI407/ICD-S%20User%20Manual.pdf
It says to check these things:
Error: Could not detect target chip
- Verify target oscillator is working.
- Check cable from ICD to target.
- Make sure that the target chip is a supported PIC16 or PIC18
Did you have a crystal and load capacitors connected to the PIC ?
Do you have a 47K pull-up resistor on the MCLR pin of the PIC ?
foodwatch
PostPosted: Fri May 09, 2008 5:26 pm     Reply with quote
be sure your target is powered from its own supply. This error will occur if your pic is not powered.
Post new topic   Reply to topic    CCS Forum Index -> CCS ICD / Mach X / Load-n-Go All times are GMT - 6 Hours
