"Out of ROM of" error when only 1/4 of ROM used
bmoore
PostPosted: Thu May 08, 2008 9:32 pm     Reply with quote
CCS PCM C Compiler, Version 4.020b
I'm getting an Error 71- Out of ROM when trying to compile a program for a PIC16F887. When I remove some code in order to get it to compile, it says ROM usage is 98%, but looking at my machine code it is only using about 2000 of the available 8192 lines in the PICs memory (about 25%).
PostPosted: Thu May 08, 2008 9:37 pm     Reply with quote
You have a special "b" version. Did it come with a board ?
If so, it might be limited to only 2K of ROM, similar to the demo version.
bmoore
PostPosted: Thu May 08, 2008 9:42 pm     Reply with quote
Yes, it came with a PICKit 2 Debug Express package... That stinks.
dyeatman
PostPosted: Fri May 09, 2008 6:10 am     Reply with quote
AFAIK all the demo versions have capability limitations of some
sort. Thats why they are called demos.....
The limitation is clearly stated in the Kit description. The following is
from the Microchip Website:
Features of PICkit 2 Debug Express:
* PICkit 2 Development Programmer/Debugger
* 44-pin demo board with PIC16F887 Midrange PIC microcontroller
* A series of 12 Lessons on assembly programming that cover I/O, A/D converters, timers, interrupts, and
data tables (All source code files are provided)
* A Debugging Tutorial on using the PICkit 2 as a debugger with the MPLAB IDE (Ch. 4 of the PICkit 2 User’s Guide)
* Getting Started in C tutorial on developing and debugging in C with a FREE CCS PCM™ Midrange C Compiler Demo* for
PIC16F887(contained on the PICkit 2 CD) *2kWord Program Limit.
* FREE! Microchip’s MPLAB IDE software for a complete code development environment
* FREE! HI-TECH PICC™ LITE C Compiler (contained on the MPLAB CD)
