| View previous topic :: View next topic   |
			40inD
  Joined: 30 Jul 2007 Posts: 112 Location: Moscow, Russia
				| how to define pins as array? |
				 Posted: Thu Apr 24, 2008 1:44 am     |
				How to define pins as array? I want to declare pins like
 	  | Code: | 	 		  A[0]=pin_A0;
A[15]=pin_B7;
and work with pins in array style i.e. On or Off the pin by this command:  |
				 Posted: Thu Apr 24, 2008 2:04 am     |
				You could declare an array of bits, and then set the base address of the
array to the address of PortA with the #locate directive.  Note that you
must also set the TRIS for the Ports, to make all pins be outputs.
Also, on the 16F877, PortA outputs A6 and A7 don't exist.   On other
PICs, one pin on PortA might be an input-only pin.
#include <16F877.H>
int1 array_of_bits[16];
#locate array_of_bits = 0x05  // Address of PortA on 16F877
int8 i;
set_tris_a(0x00);
set_tris_b(0x00);
array_of_bits[0] = 1;
array_of_bits[1] = 0;
array_of_bits[2] = 1;
array_of_bits[3] = 0;
array_of_bits[4] = 1;
array_of_bits[5] = 0;
array_of_bits[6] = 1;
array_of_bits[7] = 0;
array_of_bits[8] = 1;
array_of_bits[9] = 0;
array_of_bits[10] = 1;
array_of_bits[11] = 0;
array_of_bits[12] = 1;
array_of_bits[13] = 0;
array_of_bits[14] = 1;
array_of_bits[15] = 0;
			40inD
				 Posted: Thu Apr 24, 2008 3:28 am     |
				Hmmm. I tried to make this:
#include <16F877A.h>
#device adc=8
#FUSES XT                       //Crystal osc <= 4mhz
#FUSES WRT_50%                  //Lower half of Program Memory is Write Protected
byte R[24]; // relays array
{int i;
R[0]=pin_A4;
R[1]=pin_A5;
R[2]=pin_E0;
R[3]=pin_E1;
R[4]=pin_E2;
R[5]=pin_C0;
R[6]=pin_C1;
R[7]=pin_C2;
R[8]=pin_C3;
R[9]=pin_D0;
R[10]=pin_D1;
R[11]=pin_D2;
R[12]=pin_D3;
R[13]=pin_C4;
R[14]=pin_C5;
R[15]=pin_C6;
R[16]=pin_C7;
R[17]=pin_D4;
R[18]=pin_D5;
R[19]=pin_D6;
R[20]=pin_D7;
R[21]=pin_B1;
R[22]=pin_B2;
R[23]=pin_B4;
  setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
 for (i=0; i<=23; i++)
   output_high(R[i]);
 delay_ms(250);
And in Proteus it works fine. |
			Matro Guest
				 Posted: Thu Apr 24, 2008 3:41 am     |
				Yes, it will work.
It's simpler to implement than PCM programmer's method, but definitely less efficient.
Matro |
