| problem with LCD |
Posted: Wed Apr 23, 2008 3:28 pm |
Hi, I'm using TS1620B-7 2x16 LCD but it doesn't work on board. I'm using PIC16F877. I connected D0-E, D1-RS, D2-RW, D4-D7 -DB4-DB7, Vo and Vss 0V, Vdd 5V. It works on Proteus but doesnt work on board.Is there any extra connection for this LCD?
My codes are very simple:
#include <16F877A.H>
#fuses XT,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
#use delay (clock=4000000)
#include <lcd.c>
int a=5;
lcd_init();
printf(lcd_putc,"\f %d",a);
can u help me what is the problem? |
meereck
foodwatch
Posted: Wed Apr 23, 2008 7:54 pm |
| look at lcd.c and be sure the d port pins are set up correctly. Do you get square blocks when you first power up, but before the program hits lcdinit() |
