mxkid
| SD Card help required |
Posted: Wed Apr 16, 2008 6:39 am |
I am after a bit of help. I would like to use an SD card (or equivalent) for data storage. I want a PIC to create a .txt file (or equivalent) for storage and when the data is stored I can unplug the card from the PIC and plug it into a PC. I am looking at storing a normal 8 bit value to start with as I am taking temperature samples from the TC74 located on the PICDEM 2 board.
I recently used the 'flex_lcd.c' file as a #include file and a simple .c test program to get me up and running with the LCD display on the PICDEM 2 board which was great and I wondered if there was similar code samples available for an SD card. I also currently use a 16F877A. I know I will have to change this chip due to memory storage but is there an equivalent 18 series chip with the same pin outs?
Any circuit diagrams, datasheet links etc. . . would also be extremely useful.
In fact, any help would be great! |
Posted: Wed Apr 16, 2008 12:10 pm |
| Quote: |
same pin outs ? |
18F452 is the most compatible. 18F4520 is an enhanced version.
You need the PCH compiler for these PICs. |
mxkid
Posted: Wed Apr 16, 2008 2:29 pm |
Not sure what you mean by a PCH compiler - do you mean that the CCS compiler won't do the job? I have looked at the read me for my IDC2 and both of these IC's are compatible. |
Posted: Wed Apr 16, 2008 2:50 pm |
The "compiler" is actually at least four separate compilers that are
sold individually or bundled together in various combinations along
with the CCS IDE. Notice the table on this page shows the PCB,
PCM, PCH and PCD compilers:
http://www.ccsinfo.com/content.php?page=Purchasing1
To use the 18F chips, you must have some form of the "compiler"
that contains the PCH compiler. |
mxkid
Posted: Wed Apr 16, 2008 3:01 pm |
Ah, makes more sense now, cheers.
Is there anyway I can use my 16 series PIC to perform the task? |
asmallri
Joined: 12 Aug 2004 Posts: 1661 Location: Perth, Australia
Posted: Wed Apr 16, 2008 5:32 pm |
| PCM programmer wrote: | | Quote: |
same pin outs ? |
The PIC18F4620 is equally compatible but is better suited for generic SD/MMC card applications on the PIC requiring compatibility with the PC (FAT file system). This is because of the larger amount of RAM and Program memory of this PIC. _________________ Regards, Andrew
asmallri
Posted: Wed Apr 16, 2008 5:34 pm |
| mxkid wrote: | Ah, makes more sense now, cheers.
Not readily. The SD/MMC cards must write blocks in 512 byte chunks. This is difficult to implement on a PIC with very limited RAM. _________________ Regards, Andrew
Posted: Wed Apr 16, 2008 7:28 pm |
| mxkid wrote: | | Is there anyway I can use my 16 series PIC to perform the task? | Yes, there are several options but all have severe limitations. The basic problem is that MMC & SD cards have to be written in chunks of 512 bytes. Reading small amounts of data is no problem, you can even read a single byte if you want to, but the writing has to be done a single 512 byte block at a time. None of the PIC16 chips has enough RAM to hold 512 bytes.
The easiest solution as suggested is to use a PIC18 processor but that might require an update of your compiler. When considering a PIC18 processor make sure it can run at 3.3V, it will make your design a lot easier. Often these chips are indicated as PIC18LFxxx.
If you don't want to spend the money for another compiler than here are a few possible alternative methods using a PIC16:
1) Add an external chip that will handle the communication with the MMC or SD card. Examples are the DOSonCHIP for approx. $13, the Vinculum chip based VDRIVE2 module for about $27 and the uALFAT ($20 for chip chip, $56 for module). These are quick and reliable solutions but not cheap, so only suitable for low quantities or upgrade of existing designs.
1a) A fun option. Go crazy and use the USBwiz This module isn't cheap at $85 but gives you besides FAT32 on a SD card also a USB-host implementation! This is better than the common USB-slave implementations as you can now connect memory-sticks, USB-hard disks, keyboard, mouse and printers to your tiny PIC processor!
2) Write the data in small files with a maximum of let's say 100 bytes and fill the rest of the 512 byte blocks with a constant value (e.g. zero). A lot of memory is wasted but who cares with current low prices for the memory cards.
Disadvantage: Some kind of fixed directory/file structure has to be used. Because of the PIC16 memory limitation you can't read and modify the contents of the FAT32 structure, so this will be a write-once-and-never-change directory structure.
Or, consider using another processor type that has more RAM and can be programmed with the free GNU compiler (Atmel, ARM, MIPS, ...). |
asmallri
Posted: Thu Apr 17, 2008 7:40 am |
| ckielstra wrote: | | mxkid wrote: | | Is there anyway I can use my 16 series PIC to perform the task? | Yes, there are several options but all have severe limitations. The basic problem is that MMC & SD cards have to be written in chunks of 512 bytes. Reading small amounts of data is no problem, you can even read a single byte if you want to... |
Newer card variants when in high capacity mode must also be read in 512 byte blocks
| Quote: | | Or, consider using another processor type that has more RAM and can be programmed with the free GNU compiler (Atmel, ARM, MIPS, ...). |
You could naturally stay with the Microchip using the PIC18F, PIC24F, and dsPICs families and the free student edition of their respective compilers. IMHO it takes significantly longer to develop in these compilers than with the CCS compiler - I frequently use both Microchip and CCS compilers. _________________ Regards, Andrew
Dimmu
Posted: Thu Apr 17, 2008 1:05 pm |
Or you can use an external memory to handle you 512 bytes chunk and then write them back at once to the SD card.
Dimmu |
mxkid
Posted: Thu Apr 17, 2008 3:02 pm |
Thanks for all of your help so far, this is becoming much clearer!
I have checked my CCS compiler and it supports the PIC18F4620 PIC. I also have a good idea of how to design the circuit so building and testing it for the correct voltages etc. . should be no problem. So I think I’m good to go.
Regarding to the software side, I have had a look on the CCS forum for code examples and there are several. For example:
http://www.ccsinfo.com/forum/viewtopic.php?t=23969
Even though it's not for an SD card in the example this is the sort of thing I'm after as it gives #include files and sample code (I have both types of card so I can use an MMC card). However, the sample code does more than I require - all I want to do is create a .txt file and write data. Is it better to take all of the bits I don’t require from this example or look for another? Will this cause me problems as this is new to me? Has anyone got or knows of any examples I could use?
Thanks again! |
asmallri
Posted: Thu Apr 17, 2008 4:44 pm |
For another software library have a look at the CCS supplied drivers: mmcsd.c & fat.h
An example of using these drivers is in the example directory: ex_fat.c |
