incubi
Delays stop working if ICD=TRUE is enabled on 18F4520 |
Posted: Tue Apr 08, 2008 7:40 pm |
Does anyone know what would cause a Delay_Ms to not work when the IDC-TRUE is set? It like the delays are gone but if I load the debug everything works. I’ve tried all the options I know of but still the same issue.
#### Code snip . c ####
include "main.h"
#int_RTCC
void RTCC_isr(void)
output_bit(PIN_D1,0);
Delay_Ms(2000);
// setup_adc_ports(NO_ANALOGS|VSS_VDD);
// setup_adc(ADC_OFF|ADC_TAD_MUL_0);
// setup_psp(PSP_DISABLED);
// setup_spi(SPI_SS_DISABLED);
// setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL );
// setup_timer_1(T1_DISABLED);
// setup_timer_2(T2_DISABLED,0,1);
// setup_timer_3(T3_DISABLED|T3_DIV_BY_1);
// setup_comparator(NC_NC_NC_NC);
// setup_vref(FALSE);
enable_interrupts(INT_RTCC);
for(;;)
output_bit(PIN_D1,1);
// restart_wdt();
####3 .H #################
#include <18F4520.h>
#device adc=8
#device ICD=TRUE
//#FUSES NODEBUG
#FUSES HS //Low power osc < 200 khz
#FUSES NOBROWNOUT //Reset when brownout detected
#FUSES BORV25 //Brownout reset at 2.5V
#FUSES PUT //No Power Up Timer
#FUSES NOLVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
//#FUSES IESO //Internal External Switch Over mode enabled
//#FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
#FUSES LPT1OSC //Timer1 configured for low-power operation
#FUSES XINST //Extended set extension and Indexed Addressing mode enabled
//#FUSES CCP2C1
//#FUSES NOLPT1OSC
//#use delay(clock=4000000)
#use delay(crystal=4mhz)
//#use delay(clock=40000000,RESTART_WDT) |
Posted: Tue Apr 08, 2008 8:14 pm |
This is a problem. The extended instruction set is not supported.
Using XINST will give erratic operation. Change the fuse to NOXINST.
Do this in all of your programs. |
incubi
Posted: Tue Apr 08, 2008 9:22 pm |
Looks like that's it, man its always the little things
Thanks for the help
incubi |
incubi
Posted: Tue Apr 08, 2008 10:19 pm |
Would you happen to know why adding a var at the top/global would stop the interrupt from working? Example,
#include "main.h"
#int_RTCC
byte myvar;
void RTCC_isr(void)
Delay_Ms(500);
Seems to kill the interrupt not sure why |
Posted: Tue Apr 08, 2008 11:00 pm |
Yes. The #int_RTCC tells the compiler that the following function is
an interrupt function. You can't stick a global variable between the #int
statement and the function. Always put the #int statement on the line
just above the interrupt function. Example:
Quote: |
#int_RTCC
void RTCC_isr(void)
Delay_Ms(500);
incubi
Posted: Wed Apr 09, 2008 3:50 am |
Where was this kind of help back in the 90s when I was learning C
Thanks PCM programmer,
incubi |
