Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
Acces bank 18F452
Johan van den Heever
Acces bank 18F452
PostPosted: Wed Jan 22, 2003 1:46 am     Reply with quote
I am passing a constant to a procedure with the following def:
void command_lcd(int8 command)
PORTD = command;
This procedure is called in the main loop to as part of the lcd init procedure:
void lcd_init()
command_lcd(6);
command_lcd(12);
main
init_lcd();
My problem is the following: The correct value does not reach PORTD unless init_lcd() in the main loop is preceded by a BSR = 0 command. Is this normal? Can somebody please explain.
___________________________
Original Post ID: 10883
TSchultz
RE: Acces bank 18F452
PostPosted: Wed Jan 22, 2003 5:49 am     Reply with quote
:=I am passing a constant to a procedure with the following def:
:=void command_lcd(int8 command)
:= PORTD = command;
:=This procedure is called in the main loop to as part of the lcd init procedure:
:=void lcd_init()
:= command_lcd(6);
:= command_lcd(12);
:=main
:= init_lcd();
:=My problem is the following: The correct value does not reach PORTD unless init_lcd() in the main loop is preceded by a BSR = 0 command. Is this normal? Can somebody please explain.
What version of the compiler are you using?
I recently completed (I hope!) a project I switched over to a PIC18F452 and found a few "bugs" in the compiler mostly to do with the handling of the memory page select bits. I was using approx 900 bytes of the RAM and had to place #locate statements to manually place almost all of my varaible into specific page banks. Once I had done this most of the odd problems went away.
For example I found some problems with the compiler placing arrays across page banks. I did not take the time to verify that it generated the proper assembly to handle the page selections properly but it definitely caused problems for me. Once I moved all my arrays to manually selected areas those problems dissapeared.
I just wish they would provide a list of known issues so we all don't have to waste time troubleshooting things that are known to be bad. I do understand that the compiler is a work in progress but we knew ahead of time all the known issues it would make troubleshooting easier.
-Troy
Original Post ID: 10887
