| Ethernet........? |
Posted: Sat Apr 05, 2008 4:28 am |
I need help in Ethernet connection. I have easyPic 5 board along with its ethernet board having ENC28J60 IC and i connected it to network (LAN).
if someone can post me an example of CCS code in which i can connect to a remote computer and exchange data with it.... it will be very helpful.
Best regards,
Sohail |
Posted: Sat Apr 05, 2008 8:38 am |
Have you looked at the examples?.
ex_email.c, shows how to send a simple email.
ex_websv.c, gives a limited demo, of the PIC providing a web page, and updating an ADC value on this page.
ex_st_udp.c, shows using a UDP connection to talk between two boards.
mike Guest
Posted: Mon Apr 07, 2008 5:22 am |
But if somebody can give me a simple example of ethernet connectivity using enc28j60 driver.
It will be really helpful
because
i am not able to make connection of my hardware with ethernet.
i dont know where i need to mention the ip address and mac address and subnet mask of hardware connected to ethernet.
I need to ping it first
so if any body have a ping or simple example using enc28j60 driver.
PLZ help...... |
klebaum
| where can these examples ? |
Posted: Thu Apr 07, 2011 6:07 am |
| Ttelmah wrote: | Have you looked at the examples?.
Hello, where can these examples? The example of e-mail until I got in my directory, but the other two not, and they are exactly what I need. If it was not too much to ask, what would it be possible to send me by e-mail these examples.
Thanks.
kleber.xgames@gmail.com |
kmp65
Posted: Thu Apr 07, 2011 6:24 am |
Normally found here:
C:\Program Files\PICC\Examples |
Posted: Thu Apr 07, 2011 9:50 am |
The first two can be found in the PICC/examples directory and the last one is found in the TCP-IP Examples directory.
If you do not have these you will have to upgrade your compiler. When you download your upgrade, get the TCP-IP examples from the same download page.
We are not allowed to send them to you. That is specifically prohibited by CCS as a violation of their copyright. _________________ Google and Forum Search are some of your best tools |
klebaum
Posted: Thu Apr 07, 2011 10:13 am |
| kmp65 wrote: | Normally found here:
Normally yes, but not in this folder or any folder the files of the compiler "ex_websv.c"and "ex_st_udp.c", the version of my compiler is 4.093.
Need to implement a communication between two PIC microcontrollers, through the ethernet, so using the integrated circuit ENC28J60.
Again, who can send me two sample files eses would be grateful.
Thanks. |
klebaum
Posted: Thu Apr 07, 2011 10:17 am |
We are not allowed to send them to you. That is specifically prohibited by CCS as a violation of their copyright. |
Thanks for clarifying, then all forms will have to provide the upgrade to compile.
Thanks to everyone who helped. |
