nickpnh
| PIC24HJ #fuses options |
Posted: Mon Mar 31, 2008 7:35 am |
| I can't find the configuration settings for the C30, C18 shows all the options for the PIC18 devices, any similar list for the PIC24s or is it all the same? |
Posted: Mon Mar 31, 2008 2:31 pm |
I don't have the PCD compiler, but normally the include files (.H) for
each PIC have the list of available fuses at the start of the file.
Look in this directory:
| Quote: | | c:\Program Files\picc\Devices |
For example, the 16F877.H file has these lines in it:
| Code: | // Fuses: LP,XT,HS,RC,NOWDT,WDT,NOPUT,PUT,PROTECT,PROTECT_5%
// Fuses: PROTECT_50%,NOPROTECT,NOBROWNOUT,BROWNOUT,LVP,NOLVP,CPD
// Fuses: NOCPD,WRT,NOWRT,DEBUG,NODEBUG |
mickent
Posted: Mon Mar 31, 2008 6:49 pm |
C30 and C18 are the names of Microchip compiliers. CCS compilers are PCM, PCD, PCW etc. Are you in the right forum?
In PCW the valid fuse list can be found under "View", "valid fuses". Set your chip number at the top.
Microchip forum: http://forum.microchip.com/default.aspx _________________ Mick |
nickpnh
| PCW related to MPLAB |
Posted: Mon Mar 31, 2008 7:28 pm |
I know the fuses are all listed in the header file but I don't know what they all mean. I know they should be available in the PCW with an explanation but I don't know how to open/invoke that. I purchased PIC MCU compiler and installed it. My vendor tied it together with MPLAB IDE so that MPLAB uses the PIC MCU compiler (I believe this is how it is working).
I am jumping into co-development in an arena I am inexperienced with. He says I only need to write the functional C code and not worry about the back-end BUT I want to understand it all.
So with things installed the way they are, I should be able to invoke PCW but can't figure out how. My laptop has PICC LITE options that let me choose a device but that just opens the header file - again with no explanation of the fuses.
I am more comfortable in Linux/Unix than windows for solving tool issues.
HELP!!! _________________ What is this thing? I mean there's no useful purpose for there to be a bunch of choppy, crushy things in the middle of a hallway! |
