| jmaurin
				| Passing string as parameter and calculating parity bit |
				|  Posted: Sat Mar 29, 2008 3:48 pm |   |
				| Hi.
 I have a function to write some texts to my car's display. In this function, i need to receive a text (by parameter) and send char by char using i2c (+somethings).
 My problem is: how can i pass a string by parameter?
 Also, is there any easy way to calculate parity bit? I need to receive a string, get 10 chars from this string (is less, add a blank char) and send these 10 chars to my display using i2c_write() function.....but not only char, it's char + parity bit...so it's 9 bits.
 Now, i'm using a global variable for string and then i call EscreveDisplay(), which scans the global variable and send char-by-char. The chars are pre-calculated by me (i have a chars table in switch).
 This is how i call the function:
  	  | Code: |  	  | sprintf(e,"Test string");
 EscreveDisplay();
 where 'e' is a global variable (char[20] e="").
 This is the function:
  	  | Code: |  	  | void EscreveDisplay(){
 long i=0,t=0;
 int bitcount=0;
 #ifndef DEBUG
 Initi2c();
 MRQ = 0;
 delay_ms(1);
 MRQ = 1;
 delay_us(200);
 #ifndef DEBUG
 Starti2c();
 i2c_write(0x9b);     // Endereço do display
 MRQ = 0;
 delay_us(250);
 #ifndef DEBUG
 // Display symbols
 // Faz a contagem de bits=1 para calcular a paridade
 for (i=1;i<7;i++) {
 if (bit_test(b1,i)) {
 bitcount++;
 // Se o numero de bits for impar, o bit de paridade é 0
 // Caso contrario, é 1
 if (EvenOrOdd(bitcount)) {
 bit_clear(b1,0);
 } else {
 bit_set(b1,0);
 delay_ms(1);
 //   i2c_write(0x01);
 i2c_write(b1);
 delay_ms(1);
 i2c_write(0x01);
 delay_ms(1);
 i2c_write(0x01);
 delay_ms(1);
 t = strlen(e);
 #ifdef DEBUG
 printf("Tamanho da string: %u\n\r",strlen(e));
 for (i=0;i<t;i++) {
 if (i<10) {
 if (e[i]==NULL) {
 #ifdef DEBUG
 printf(" Achei nulo\n\r");
 e[i]=" ";
 #ifdef DEBUG
 printf("  Escrevendo caracter %c\n\r",e[i]);
 #ifndef DEBUG
 switch( e[i] ) {
 case ' ': i2c_write(0x40); break;
 case '@': i2c_write(0x80); break;
 case '~': i2c_write(0xFD); break;
 case ',': i2c_write(0x58); break;
 case '+': i2c_write(0x57); break;
 case '/': i2c_write(0x5E); break;
 case '\\': i2c_write(0xB9); break;
 case '|': i2c_write(0xF8); break;
 case '{': i2c_write(0xF7); break;
 case '}': i2c_write(0xFB); break;
 case '"': i2c_write(0x45); break;
 case '#': i2c_write(0x46); break;
 case '$': i2c_write(0x49); break;
 case '&': i2c_write(0x4C); break;
 case '\'': i2c_write(0x4F); break;
 case ';': i2c_write(0x76); break;
 case '<': i2c_write(0x79); break;
 case '>': i2c_write(0x7C); break;
 case '.': i2c_write(0x5D); break;
 case ':': i2c_write(0x75); break;
 case ')': i2c_write(0x52); break;
 case '(': i2c_write(0x51); break;
 case '%': i2c_write(0x4A); break;
 case '=': i2c_write(0x7A); break;
 case '?': i2c_write(0x7F); break;
 case '-': i2c_write(0x5B); break;
 case '*': i2c_write(0x54); break;
 case '!': i2c_write(0x43); break;
 case '0': i2c_write(0x61); break;
 case '1': i2c_write(0x62); break;
 case '2': i2c_write(0x64); break;
 case '3': i2c_write(0x67); break;
 case '4': i2c_write(0x68); break;
 case '5': i2c_write(0x6B); break;
 case '6': i2c_write(0x6D); break;
 case '7': i2c_write(0x6E); break;
 case '8': i2c_write(0x70); break;
 case '9': i2c_write(0x73); break;
 case 'a': i2c_write(0xC2); break;
 case 'b': i2c_write(0xC4); break;
 case 'c': i2c_write(0xC7); break;
 case 'd': i2c_write(0xC8); break;
 case 'e': i2c_write(0xCB); break;
 case 'f': i2c_write(0xCD); break;
 case 'g': i2c_write(0xCE); break;
 case 'h': i2c_write(0xD0); break;
 case 'i': i2c_write(0xD3); break;
 case 'j': i2c_write(0xD5); break;
 case 'k': i2c_write(0xD6); break;
 case 'l': i2c_write(0xD9); break;
 case 'm': i2c_write(0xDA); break;
 case 'n': i2c_write(0xDC); break;
 case 'o': i2c_write(0xDF); break;
 case 'p': i2c_write(0xE0); break;
 case 'q': i2c_write(0xE3); break;
 case 'r': i2c_write(0xE5); break;
 case 's': i2c_write(0xE6); break;
 case 't': i2c_write(0xE9); break;
 case 'u': i2c_write(0xEA); break;
 case 'v': i2c_write(0xEC); break;
 case 'w': i2c_write(0xEF); break;
 case 'x': i2c_write(0xF1); break;
 case 'y': i2c_write(0xF2); break;
 case 'z': i2c_write(0xF4); break;
 case 'A': i2c_write(0x83); break;
 case 'B': i2c_write(0x85); break;
 case 'C': i2c_write(0x86); break;
 case 'D': i2c_write(0x89); break;
 case 'E': i2c_write(0x8A); break;
 case 'F': i2c_write(0x8C); break;
 case 'G': i2c_write(0x8F); break;
 case 'H': i2c_write(0x91); break;
 case 'I': i2c_write(0x92); break;
 case 'J': i2c_write(0x94); break;
 case 'K': i2c_write(0x97); break;
 case 'L': i2c_write(0x98); break;
 case 'M': i2c_write(0x9B); break;
 case 'N': i2c_write(0x9D); break;
 case 'O': i2c_write(0x9E); break;
 case 'P': i2c_write(0xA1); break;
 case 'Q': i2c_write(0xA2); break;
 case 'R': i2c_write(0xA4); break;
 case 'S': i2c_write(0xA7); break;
 case 'T': i2c_write(0xA8); break;
 case 'U': i2c_write(0xAB); break;
 case 'V': i2c_write(0xAD); break;
 case 'W': i2c_write(0xAE); break;
 case 'X': i2c_write(0xB0); break;
 case 'Y': i2c_write(0xB3); break;
 case 'Z': i2c_write(0xB5); break;
 default:  i2c_write(0x40); break;
 delay_ms(2);
 } else {
 #ifdef DEBUG
 printf("=> Passou do limite!Ignorando caracter %c\n\r",e[i]);
 if (t<10) {
 for (i=0;i<10-t;i++) {
 #ifdef DEBUG
 printf("----> Completando caracter %Lu\n\r",i);
 #ifndef DEBUG
 i2c_write(0x40);
 delay_ms(2);
 MRQ = 1; // MRQ = 1 // (Entrada?)
 delay_us(200);
 #ifndef DEBUG
 //      Stopi2c();
 #ifdef DEBUG
 printf("Fim da escrita no display!\n\r");
 return;
 If is possible, i like to just call: EscreveDisplay("My text");
 Thanks!
