EricKoh1985
Problem in using "fgets()" for UART |
Posted: Fri Mar 14, 2008 3:57 am |
Here, i would like to do a password system to turn ON RB0's LED. For example, the password is "1111".
My problem is i don't know how to use "fgets()" for UART.
Below is my code (with missing code for "fgets()"):
#include <16F628A.h>
#fuses XT, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP,HS
#include <stdio.h>
#use rs232(baud=9600, xmit=PIN_B2, rcv=PIN_B1)
printf("Please enter password\n");
if (fgets( )) //inside the () should be the password code "1111"
output_a(0b00000001);
printf("Password Wrong\n");
Picture of Cirucit Design: http://www.imagehosting.com/show.php/1629177_UART.JPG.html
Thanks. |
SherpaDoug
Posted: Fri Mar 14, 2008 7:38 am |
Here is the example right out of the help files:
Code: | char string[30];
printf("Password: ");
gets(string);
if(strcmp(string, password))
printf("OK");
You only need fgets() instead of gets() if you are using streams. _________________ The search for better is endless. Instead simply find very good and get the job done. |
EricKoh1985
Posted: Sun Mar 16, 2008 10:02 am |
Since my LED will only turn ON when password is '1111'. So, is it i need to replace 'password' with '1111'?
i have modified the code, as below
#include <stdio.h>
char string[30];
gets(string);
if (strcmp(string,1111))
output_b(0b00000001);
printf("OK");
printf("Password Wrong");
Why when the password is wrong, the RB0 still can turn ON and program display "OK"? (Password command seem likes is not working)
How can i make my program will only display "OK" when password is '1111', other password will display "Password Wrong"? |
Wayne_
Posted: Mon Mar 17, 2008 2:25 am |
1111 in your code is not a string but a number. To change it to a string so that strcmp will work put " around it.
Also, strcmp returns 0 for a match so your code will produce the wrong result.
Change to
if (strcmp(string, "1111") == 0)
I also had the following problem, this may not be an issue with your version of the compiler but.
strcmp does not work with string litterals "abcde" but will only work with pointers so I had to do the following.
char match[80];
strcpy(match, "1111"); // Copy "1111" to match array
if (strcmp(string, match) == 0) {
hope this helps. |
