		| Author | Message |
		| Mike M Guest
				| Trouble with simple I/O on pic16f88 |
				|  Posted: Fri Mar 14, 2008 3:23 am |   |
				| Hi,
 I´m newbie in programming pics, and I´m having some trouble with a pic16f88.  As a first test, I wanted to see if I could make output pins in diferent ports toggle high and low.
 What I have noticed is that everything works fine in portB but it does nothing on portA. I´m using an external cristal oscilator on ports A7 and A6, can this be the problem?
 The version of the complier is 4.016.
 Thanks for your help
		| Foppie
				|  Posted: Fri Mar 14, 2008 3:34 am |   |
				| first: can you post your simple test program? The guys here can give you more useful hints and tips when they see your code.
 second: the compiler v4.016 is known to be buggy, in fact all compiler before v4.020. Maybe you can update your compiler?
		| Guest
				|  Posted: Fri Mar 14, 2008 4:34 am |   |
				| OK, here´s my code:
  	  | Code: |  	  | #include <16f88.h>
 #fuses xt,NOWDT,noput,noprotect,nomclr,NOBROWNOUT,nolvp
 #include <ctype.h>
 #use DELAY(clock=4000000)
 #use fast_IO(A)
 main()
 //port_a_pullups(true);
 SETUP_ADC_PORTS(NO_ANALOGS);
 SETUP_ADC(ADC_OFF);
 set_tris_b(0x00);
 output_high(PIN_A0);
 output_high(PIN_A1);
 output_high(PIN_A2);
 //set port b as outputs
 output_low(PIN_A0);
 output_low(PIN_B7);
 output_high(PIN_B7);
 output_low(PIN_A1);
 output_low(PIN_A2);
 So, for portB the pin toggles right but for portA it does nothing.
		| Mike M Guest
				| I solved it! |
				|  Posted: Fri Mar 14, 2008 5:23 am |   |
				| Finally I solved the problem.
 It´s a RMW problem, I fixed it shadowing the port as it says in one of the old posts
 Thanks to all!
