Another MMC Over SPI FAT32 code!
Goto page Previous  1, 2, 3, 4, 5, 6  Next
Post new topic   Reply to topic    CCS Forum Index -> Code Library
wATAw
PostPosted: Wed Mar 12, 2008 11:38 am     Reply with quote
Hey,
I am trying to run this library in a 18F2550, but i only manage to work MMCInit(). When i try to write any file, the SD lose the format, so i think it writes something, but it writes wrong.
Do you know what it could be?
I use 1k resistors and 3.3 zener diodes in SCL,CS and SDO. And a 100k pull-up resistor in SDI.
Thank you very much!!
BLL
PostPosted: Wed Mar 12, 2008 4:22 pm     Reply with quote
Some routines increase the clock speed after switching the card into SPI mode. If the clock is too fast you will have problems! I need div64 on a 2620 using a 20MHz oscillator in HS mode. Any less and it doesn't work.
wATAw
PostPosted: Thu Mar 13, 2008 3:12 am     Reply with quote
do i have to use a clock divisor if i am using software SPI? I thought the clock divisor only was for hardware SPI, but i am trying with it. Wink
Thank you!
wATAw
PostPosted: Thu Mar 13, 2008 5:20 am     Reply with quote
When i try with the example of the library, it show this message:
MMC Initialized
Error 1st file in list was probably a dir.
Also when i try to write the sd, sometimes it lose the format....
I donĀ“t know what could it be.....can someone, who has it working with a 18f2550/18f4550, help me??
BLL
PostPosted: Thu Mar 13, 2008 10:44 am     Reply with quote
Haven't used software SPI at all, so can't help.
gremi
PostPosted: Fri Mar 14, 2008 8:15 am     Reply with quote
Is it possible to use this driver for a SD card or is it just for MMC ?
thanks
BLL
PostPosted: Fri Mar 14, 2008 10:29 am     Reply with quote
Works for both SD and MMC and will even tell you which you inserted!
gremi
PostPosted: Fri Mar 14, 2008 10:35 am     Reply with quote
thanks Smile
xokolatecake
PostPosted: Mon Mar 17, 2008 6:32 am     Reply with quote
When you read the fat table address you reverse the order of the bytes, why is that? does that apply to everything that is read from the card?
thanks=)
entc_610
WriteSector
PostPosted: Sun Mar 30, 2008 4:17 am     Reply with quote
hey! in the initial part of the forum here, it was mentioned that there was some error in the WriteSector, and it was corrected....i havent been able to find it, though.... it would be of great help if someone posted the changes...
waiting in anticipation....
Ivanovitx
PostPosted: Wed Apr 02, 2008 12:19 pm     Reply with quote
Hi, I have the same problem than wATAw
MMC Initialized
I'm working on a pic18F258 with a 512MB micro SD card and a micro SD to SD adapter on port A.
Here is the code that I've modified:
/ Change the port to whatever port you are going to use
#use FAST_IO(a)
// Change this to set the right tris for your pins
#define SET_MMC_TRIS() set_tris_a(0b0001000) // 0b0001000 1=input,0=output
// Change these pins to whatever pins you are using
#define ChipSel pin_A0 // Chip-Select pin
#define ChipClk pin_A2 // SPI-Clock pin
#define ChipDout pin_A1 // SPI-Data out pin
#define ChipDin pin_A3 // SPI-Data in pin
Can someone help us?
Lots of thanks!
Ivan[/code]
Ivanovitx
PostPosted: Sat Apr 05, 2008 4:02 am     Reply with quote
Now, I'm trying with a MMCplus card Transcend 512MB, but the results are the same than SD card:
MMC Initialized
Crying or Very sad Some idea?
Thanks!
Ivanovitx
PostPosted: Tue Apr 29, 2008 10:53 am     Reply with quote
I test with an MMC 128MB card and now appears the message:
MMC init failed!
Somebody has this code working??
Thanks!
denkov
View user's profile Send private message ICQ Number
make a directory on MMC
PostPosted: Mon Sep 15, 2008 8:03 pm     Reply with quote
10X Miniman
10X TOMY
Is a great job !
How can i use this code to make a directory?
ShellTox
PostPosted: Sun Jan 11, 2009 5:17 pm     Reply with quote
Hello Very Happy
I'm trying to use a 512MB Mobile MMC card and a PIC18F4550 to build a data logger. I'm able to initiate the MMC and the FAT (I'm using a 16x2 LCD to see some debug messages).
I'm trying to use the first example in the .c which appends some text to the EVENTs.LOG file. The program runs until the end, but when I read the card in my pc the EVENTS.LOG remains the same.
I've formated my card with FAT32, with 512bytes per sector. I've created a .txt and altered the name and extension to EVENTS.LOG. Then I copied this file to the MMC card. I've also changed the .c to comply my hardware:
// Change the port to whatever port you are going to use
#use FAST_IO(A)
#define SET_MMC_TRIS() set_tris_a(0b0000100) // 0b0001000 1=input,0=output
#define ChipSel      pin_A5 // Chip-Select pin
#define ChipClk      pin_A4 // SPI-Clock pin
#define ChipDout       pin_A3 // SPI-Data out pin
#define ChipDin      pin_A2 // SPI-Data in pin
The Data out from pic is connected to data in from card;
The Data in from pic is connected to data out from card.
My main follows:
#include <18F4550.h>
#include <string.h>
#include <MMC_SPI_FAT32.h>
#fuses HS,NOWDT,NOPROTECT,BROWNOUT,NOLVP,NOCPD
#ZERO_RAM
#include "flex_lcd.c"
#include "MMC_SPI_FAT32.c"
void setup(){
   lcd_init();
   if(MMCInit() == MMC_OK)  {
       printf(lcd_putc,"MMC init OK\n");
      InitFAT();
      printf(lcd_putc,"FAT init OK\n");
      printf(lcd_putc,"\f");
void main(){
   char f,gfilename[12];
   char * msg;
   setup();
      strcpy(gfilename,"EVENTS.LOG");
      f = fopen(gfilename,'a'); // open EVENTS.LOG for append
   if (f & MMC_ERROR)
      printf(lcd_putc,"Couldn't open file!\n");
      if(f == MMC_NO_CARD_INSERTED)
         printf(lcd_putc,"Please, insert MMC!");
      else if(f == MMC_MAX_FILES_REACHED)
         printf(lcd_putc,"ops.. =)");
      printf(lcd_putc,"START Writing\n");
      strcpy(msg,"Written!");
      printf(lcd_putc,msg);
      fputstring(msg,f);
      fclose(f);
      printf(lcd_putc,"\nEND Writing");
At this point I don't know what to try next, because the EVENTS.LOG doesn't change.
Can anyone help me resolve this problem? I've read all this thread and I think I'm in the same step as incubus22 was in the middle of page 3.
Thank you
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
Page 4 of 6
