		| Author | Message |
		| JaKo Guest
				| Problems with the dsPICDEM-Board |
				|  Posted: Fri Feb 29, 2008 5:38 am |   |
				| Hey guys
 I bought the dsPICDEM-Board and now I program the SPI with
 because I need the SPI for the LCD-Display. And the problem is that i get a clock but my data won´t get send. And I also programmed the LED. If i use 	  | Code: |  	  | #use spi(FORCE_HW, BITS=16, STREAM=SPI_STREAM) |
 the stop lighting, and if i use , the LEDs lights but there is no clock and data for the SPI. 	  | Code: |  	  | #use spi(FORCE_HW, BITS=16, STREAM=SPI_STREAM) |
 Can somebody help me please?
 JaKO
		| PCM programmer
		| JaKo Guest
				| dsPICDEM BOard |
				|  Posted: Tue Mar 04, 2008 6:36 am |   |
				| dsPICDEM2     	DM300018
 JaKo
		| JaKo Guest
				| Source code |
				|  Posted: Tue Mar 04, 2008 7:01 am |   |
				| That´s my source code:
  	  | Quote: |  	  | #include<30F4011.h> #fuses HS,NOWDT,NOPROTECT
 #use rs232(baud=9600, UART1)
 #define LCDLINE1CMD     0x80;
 unsigned char DisplayData[] = "Das dsPICDEM2   ";
 int8 x;
 //	char c;
 //	c="A";
 delay_ms(250);
 output_high(PIN_B0);
 output_low(PIN_B1);
 delay_ms(250);
 output_high(PIN_B1);
 output_low(PIN_B0);
 SETUP_SPI(SPI_MASTER|SPI_H_TO_L|SPI_CLK_DIV_64);
 SPI_WRITE(DisplayData);
 x=SPI_READ(0);
		| PCM programmer
				|  Posted: Tue Mar 04, 2008 12:35 pm |   |
				| Here's the page for that board. http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en023561
 The User's Guide explains how to write a driver for the LCD controller
 in this section.  But, they don't tell you what SPI mode is required.
 Here is the section in the manual that tells how to program the LCD.
  	  | Quote: |  	  | B.3 LCD SOFTWARE SPECIFICATION |
 The page above also has a download called "Software Files".  It contains
 sample C source code for the LCD driver. The filename is SPI_for_LCD.c.
 It contains these functions:
  	  | Quote: |  	  | SPI_Init(void) WriteSPI_to_LCD(void)
 It mostly consists of low-level code that writes directly to dsPIC registers.
 You could translate it to CCS.
 I don't have the PCD compiler, and I don't have time to translate these
 routines for you now.  I can't really help much more.
