DSPIC33 and setup_oscillator() problems.. a solution..
ik1wvq
PostPosted: Mon Feb 18, 2008 12:28 pm     Reply with quote
HI all,
i try to use the SETUP_OSCILLATOR function with DS33.
The results was bad, and then i wrote this simple code to program
PLL and switch oscillator.
WARNING: this is valid ONLY for DS33.
Enjoy..
regards
Mauro ik1wvq
PS.: my english is bad, but the code is working!
// costants for "DS33_OSC_CONFIG()")
// first parameter (only one)
#define Fast_RC_Oscillator 0b00000000
#define Fast_RC_Oscillator_PLL 0b00000001
#define Primary_Oscillator 0b00000010
#define Primary_Oscillator_PLL 0b00000011
#define Secondary_Oscillator 0b00000100
#define Low_Power_RC_Oscillator 0b00000101
#define Fast_RC_Oscillator_Div16 0b00000110
#define Fast_RC_Oscillator_DivN 0b00000111
// second parameter (one or more ORed)
#define switch_osc 0b00000001
#define abil_SEC_OSC_LP 0b00000010
#define lock_modify_pin_IO 0b01000000
#define unlock_modify_pin_IO 0b00000000
void DS33_osc_config(unsigned int16 valueHI,unsigned int16 valueLO)
// VALID ONLY FOR DS33
#asm asis
MOV valueHI,w0
MOV #0x743, w1 ; OSCCONH 0x743
MOV #0x78, w2
MOV #0x9A, w3
MOV.B w2, [w1]
MOV.B w3, [w1]
; write valoreHI on OSCCONH
MOV.B w0, [w1]
MOV valueLO, w0
MOV #0x742, w1 ; OSCCONL 0x742
MOV #0x46, w2
MOV #0x57, w3
MOV.B w2, [w1]
MOV.B w3, [w1]
; write valoreLO on OSCCONL
MOV.B w0, [w1]
#endasm
daraos
PostPosted: Mon Jan 26, 2009 9:30 am     Reply with quote
Thanks Mauro! that's exactly what I was looking for, the clock in the 33f is a real pain in the neck. Now, what I can't do, is configure the pre, post & clockdiv, the 33f assembler is waaay too much for me. If I can make it work, I'll post my code, or if you already have it, please share! Very Happy
EDIT:
I made it work Cool
so, the final code to make a 33f work at nearly 40 MIPS with the internal oscillator is:
#byte CLKDIV_L=0x0744
#byte CLKDIV_H=0x0745
#byte PLLFBD_L=0x0746
#byte PLLFBD_H=0x0747
//Configure multipliers N1=0, N2=0, M=43
PLLFBD_L=41;
PLLFBD_H=0x00;
CLKDIV_L=0x00;
CLKDIV_H=0x00;
#asm asis
MOV 0x00,w0
MOV #0x743, w1    ;OSCCON_H 0x743
MOV #0x78, w2
MOV #0x9A, w3
MOV.B w2, [w1]
MOV.B w3, [w1]
MOV.B w0, [w1]
MOV 0x01, w0
MOV #0x742, w1    ;OSCCON_L 0x742
MOV #0x46, w2
MOV #0x57, w3
MOV.B w2, [w1]
MOV.B w3, [w1]
;write bit to switch from FRC to FRC_PLL
MOV.B w0, [w1]
#endasm
This datasheet has all the info about the clock configuration
http://ww1.microchip.com/downloads/en/DeviceDoc/70186b.pdf
The one I used is a dsPIC33FJ128GP802
logical
PostPosted: Wed Mar 31, 2010 8:12 am     Reply with quote
Sorry to dig up and old post but how would I go about using the above.
I have a DSPIC33FJ128GP804
Basically I can get it to run fine on the internal oscillator on 7.37M, as soon as I try to increase the speed using the PLL, problems start.
Even with doing SPI Writes, the clock scores under 2MHZ based on SPI_CLK_DIV_4
I have looked through the datasheets and fully understand the configurations but unsure where to change those values from within PICC.
Even tried with things like:
#use delay(clock=73.7M,internal)
#use delay(clock=73.7M,internal=7.37M) etc
THanks
Chris
#FUSES NOWRTB                   //Boot block not write protected
#FUSES NOBSS                    //No boot segment
#FUSES FRC_PLL             //Internal Fast RC Oscillator with PLL Enabled
#FUSES NOCKSFSM                 //Clock Switching is disabled, fail Safe clock monitor is disabled
#FUSES OSCIO                    //OSC2 is general purpose output
#FUSES NOPR                     //Pimary oscillaotr disabled
#FUSES NOWINDIS                 //Watch Dog Timer in Window mode
#FUSES WPRES128                 //Watch Dog Timer PreScalar 1:128
#FUSES WPOSTS16                 //Watch Dog Timer PostScalar 1:32768
#FUSES PUT64                   //Power On Reset Timer value 128ms
#FUSES IOL1WAY                  //Allows only one reconfiguration of peripheral pins
#FUSES NOIESO                   //Internal External Switch Over mode disabled
#FUSES NORSS                    //No secure segment RAM
#FUSES NOSSS                    //No secure segment
#FUSES NOWRTSS                  //Secure segment not write protected
#FUSES NORBS                    //No Boot RAM defined
#FUSES NOCOE                    //Device will reset into operational mode
#FUSES ICSP3                    //ICD uses PGC3/PGD3 pins
#FUSES NOALTI2C                 //I2C mapped to alternate pins
daraos
PostPosted: Wed Mar 31, 2010 9:14 am     Reply with quote
Try pasting the code I posted inside the main. The delay should be clock=40M
The pic must start slow and in the code you must increase the speed. so, do it like this:
//put all your fuses here
void main(){
//init your variables here
//this code sets the multipliers
PLLFBD_L=41;
PLLFBD_H=0x00;
CLKDIV_L=0x00;
CLKDIV_H=0x00;
#asm asis
MOV 0x00,w0
MOV #0x78, w2
MOV #0x9A, w3
MOV.B w2, [w1]
MOV.B w3, [w1]
MOV.B w0, [w1]
MOV 0x01, w0
MOV #0x46, w2
MOV #0x57, w3
MOV.B w2, [w1]
MOV.B w3, [w1]
MOV.B w0, [w1]
#endasm
//here you put your code. for example:
   while(TRUE){
      output_toogle(pin_b0);
//this code should give you a 5MHz pulse in pin B0 (I think, could be faster or slower :P), that's because the code use several instructions per pulse.
If the code don't do anything, try reducing PLLFBD_L=41; to 40, 39, 38, etc, that will make the pic slower but more stable.
That's all the help I can give you, I haven't used that pic in a long time and don't have the code with me
logical
PostPosted: Wed Mar 31, 2010 9:34 am     Reply with quote
Fantastic thanks, will give that a try later this evening and will post the result.
petiot
this code should do it
PostPosted: Mon Jun 28, 2010 8:28 am     Reply with quote
hi,
Looking at the assembly generated, this code should do it. I have not tried it though.
/* PLL special function registers*/
#byte OSCCON_H=0x0743
#byte OSCCON_L=0x0742
#bit  OSWEN=OSCCON_L.0
#bit  LOCK= OSCCON_L.5
void switch_osc()
//Configure PLL N1=0, N2=0, M=43 for 40MIPS 80Mhz operation
PLLFBD_L=41;
PLLFBD_H=0x00;
CLKDIV_L=0x00;
CLKDIV_H=0x00;
OSCCON_H=0x78; //OSCON_H unlock
OSCCON_H=0x9A;
OSCCON_H=0x01; //sets NOSC bits for FRC with PLL
OSCCON_L=0x46; //OSCON_L unlock
OSCCON_L=0x57;
OSCCON_L=0x01;
while(OSWEN==1);
regards,
serge
