Lykos1986
| Serial communication for AT commands... |
Posted: Tue Feb 12, 2008 6:57 pm |
Hello to everyone!
I am trying to set up a communication between a Telit GM862 GSM Module and a PIC 16F877. I need a serial communication 9600 8 N 1 without hardware control (like the hyper terminal). So I am typing:
#use rs232(baud=9600, xmit=PIN_C7,rcv=PIN_C6, PARITY=N, BITS=8)
Is that right? |
Posted: Tue Feb 12, 2008 9:42 pm |
Look at the pin definitions in the Overview section of the 16F877 data
sheet. (page 11 in the Acrobat reader).
http://ww1.microchip.com/downloads/en/DeviceDoc/30292c.pdf
What pin is assigned to the UART Tx and what pin is for Rx ?
Then look closely at your #use rs232() statement. |
Posted: Wed Feb 13, 2008 3:09 am |
Yes… I know exactly what you mean! The transmit pin and receive pins they have to be opposite! But the problem is on hardware and I cannot change it that!
I think with the CCS we can use an asynchronous serial communication with any pins! Just software serial and not the hardware! How can I do that and also to be 9600 8 N 1? |
KU5D
Joined: 10 Feb 2008 Posts: 46 Location: Asheville, North Carolina
Posted: Wed Feb 13, 2008 5:38 am |
If you're wanting a software UART,just pick the pins you wanna use and assign the thing to a stream such as:
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,stream=PC)
Then if you want to squirt something out the serial port:
fprintf(PC,"\r\n\This does a carriage return and linefeed...and prints this.");
This works on the 18F4520. I've never played with the 877 but I think they're similar in this respect. _________________ Confidence is the feeling you have right before you fully understand the situation... |
Lykos1986
Posted: Wed Feb 13, 2008 8:32 am |
Ok… I start getting crazy with that project! I just want to take an “OK” respond from my Telit GM862 module! The problem is that I generally take an echo respond and not OK! What is happening?
I have post my code here:
#include <16F877A.h>
#fuses XT,NOWDT,NOPUT,NOPROTECT,NOBROWNOUT,NOCPD,NOWRT,NOLVP
#use delay (clock=4000000)
#use rs232(baud=9600, xmit=PIN_C7,rcv=PIN_C6,PARITY=N, BITS=8, stream=PC) //
#include <string.h>
#define L1 pin_c1
#define L2 pin_c2
#define F1 pin_e1
#define F2 pin_e0
#define power pin_d7
#define module_led pin_d6
char string1[10];
char string2[10];
void module_on() //Turns on the GSM Module
output_high(power);
delay_ms(1200);
output_low(power);
input(module_led);
output_high(L2);
strcpy(string2,"OK");
if(input(F1))
module_on();
if (input(F2))
fprintf(PC, "AT\r\n");
gets(string1);
if(!strcmp(string1, string2))
output_high(L1);
Lykos1986
Posted: Thu Feb 14, 2008 7:39 am |
| Any help? |
Foppie
Joined: 16 Sep 2005 Posts: 138 Location: The Netherlands
Posted: Thu Feb 14, 2008 8:06 am |
most modems I know turn at command echo off with the ate0 command...
But I can advise you to make a more advanced respons filter. Maybe you should try a receiving buffer or something like that? Search this forum for something like that, I have seen several good examples in the past. |
Posted: Thu Feb 14, 2008 8:54 am |
| the problem is that the Telit GSM Module have got no echo by defult. So... maybe is a software error... |
SET
Posted: Thu Feb 14, 2008 9:33 am |
I'm doing a Telit app right now, and my GM862 does echo by default..
The other poster is correct, you have to be a bit more sophisticated, get the response from the module and then parse it. |
Posted: Fri Feb 15, 2008 7:57 am |
| SET wrote: | I'm doing a Telit app right now, and my GM862 does echo by default..
I don’t know how much sophisticated can be the code!
I was thinking that the module after the AT command will answer me just with the OK and nothing more! I was working before using only the module (not the same) and my PCs hyper terminal. The result was as I expecting! I was sending the AT command and the module answers with OK. Of course that was happening with all the other AT commands! I was not taking something more from then module! No echo not other characters…
How I can build something like that? Something that works like the hyper terminal to my PIC? |
SET
Posted: Fri Feb 15, 2008 8:21 am |
| I think you have your Tx/Rx reversed - the Telit units are a bit confusing, 'Tx' is actually the input and is therefore connected to Tx on the PIC (C6). So you can use the hardware UART. |
Posted: Fri Feb 15, 2008 8:34 am |
| Yes… I know that problem but I have already built my PCB. I cannot use a software UART that communicates like the windows hyper terminal? |
SET
Posted: Fri Feb 15, 2008 8:40 am |
| So C7 (on the PIC) is connected to Pin 25 on the GM862? |
Lykos1986
Posted: Fri Feb 15, 2008 9:23 am |
Pin 25? No…
PIC pin C7 => GM863 pin 20
PIC pin C6 => GM862 pin 37
And the the pin 45 of the GM862 to the ground, because I don’t want to use hardware flow control.
PS:
I don’t use Python, just the regular serial communication and the AT Commands |
SET
Posted: Fri Feb 15, 2008 9:39 am |
| Lykos1986 wrote: | Pin 25? No…
PS:
Apologies that was GC864 pinout I quoted .. (we use both!).
So your correct, your hardware is reversed. The soft UART should work Ok though, assuming 'gets ' works. If you have in-circuit debug working, can you put a breakpoint after the gets to see what string1 contains? |
