nehallove
| sleep() function problem with 18f2520 |
Posted: Wed Jan 30, 2008 2:52 pm |
Hi guys,
I am working on the project in which i have to wake up the unit from sleep mode after detecting the comparator output of the 18f2520's port pin.
Problems which i face are ...
1. comparator interrupt works pretty good without putting sleep function in. but whenever i put sleep function comparator interrupt fires even if there isn't possible condition to fire it up. and unit comes out of sleep.
2. if i remove sleep function then it works great. so is it debugger which messing it up or something else.
setup_comparator(A0_A3_NC_NC_OUT_ON_A4); // a0 & a3 comparator
setup_vref(FALSE); // input and a4 is output
enable_interrupts(INT_COMP); // Initialize the Comparator interrupt
enable_interrupts(GLOBAL); // Enable the requested interrupts
sleep();
while(1){
output_low(PIN_C2);
output_high(PIN_C2);
#INT_COMP
void isr()
disable_interrupts(INT_COMP);
clear_interrupt(INT_COMP);
delay_ms(1000); // *** TEST CODE, wait to see if it works
output_high(PIN_C2); // *** TEST CODE, turn on LED
return;
regards: _________________ nehal |
Posted: Wed Jan 30, 2008 3:31 pm |
_Clear_ the comparator interrupt before enabling it.
Remember it will already be set, if _any_ comparator event has already occured.
Unless you really 'need' to have the interrupt handler, get rid of it, and remove the 'global' interrupt enable. The interrupt will _wake_ the chip when it fires, even if the global enable is off, and execute the next instruction. So:
while (true) {
sleep();
delay_cycles(1); //The instruction after the sleep is 'prefetched'
//This ensures it is a NOP
output_low(PIN_C2);
With your comparator setups, this should sleep, and respond immediately (only a couple of instruction times delay), when the interrupt triggers, while the 'interrupt handler' approach, will add about 30 instruction times delay to this.
Posted: Thu Jan 31, 2008 11:48 am |
hey thanks for the help.
i already did same way you showed me, but it didn't work. it doesn't go to sleep at all. it remains in constant loop. It responses to comparator interrupt but if i remove comparator interrupt then it doesn't have any problem going to sleep. Is any relationship between comparator interrupt and sleep mode???
nehal |
