Setting ICD-U in the PCWHD IDE
boatdrinks
PostPosted: Sat Jan 26, 2008 10:19 am     Reply with quote
Guys,
I've got the latest version of the compiler along with an ICD-U unit. I have installed the drivers correctly, and I can open the stand alone IDC application to talk, test and even transfer a HEX file to my micro controller.
The problem I am running into is that I can not program or debug a program directly from the CCS environment. Each time I try to connect to the ICD-U it brings up the ICD-S connections window and I can not find the location to change the settings to look at the ICD-U.
Any help would be greatly appreciated.
thanks,
picGirL
ICD-U40 Set-up
PostPosted: Sat Jan 26, 2008 11:38 am     Reply with quote
I am having a similar problem and am using a pic start to get around it
If anyone have any info it would be greatly appreciated! Wink
I am working on my college senior design project and its getting close to graduation
