Porting a program designed for 4MHz to 20MHz
archcvd
PostPosted: Thu Jan 17, 2008 12:11 pm     Reply with quote
I am fairly new at this so hopefully this is an obvious one for someone.
When porting a program that was designed with 4MHz as the speed in mind to a 20MHz platform, does one need to change more than the following value?
I assumed that when one changes this statement to the proper clock speed all the delays get updated automatically, but I can't seem to get my project to run with the code.
The code itself seemed fairly universal save for this fact. So I am hoping this is the problem I overlooked. If not, I will post more details.
PostPosted: Thu Jan 17, 2008 12:23 pm     Reply with quote
You need to change the fuse from XT to HS. Otherwise, the 20 MHz
crystal won't oscillate.
Humberto
PostPosted: Thu Jan 17, 2008 12:25 pm     Reply with quote
You also need to tell the compiler to change the Configuration Word because the MCU use
a different oscillator configuration, XT is used up to 4Mhz, to run at 20Mhz it is necesary to use HS.
Humberto
Edited:
Sorry PCM. almost the same answer, hope it will help to the poster.
newguy
PostPosted: Thu Jan 17, 2008 12:28 pm     Reply with quote
You also have to pay attention to timers to ensure that timer interrupts, PWM frequency/duty cycle, etc happen at the same rate as for the 4MHz case.
archcvd
I will use the PIC wizard to set the fuse to HS. If I am using the 16F819 am I correct in assuming that I do not need an external crystal for my project? I'm making this assumption because reading CCS C automatically sets the clock speed of the PIC to 20MHz when selecting this particular PIC from the drop down menu.
Humberto
PostPosted: Thu Jan 17, 2008 12:38 pm     Reply with quote
The PIC wizard is not so clever as you will suppose to set such configuration
automatically for you. It is a kind of help but you should check if the generated code
is applicable or not reading the Microchip Datasheet for the corresponding MCU.
Nop. To run at such speed you must use an external crystal.
Humberto
zonemikelguest
PostPosted: Thu Jan 17, 2008 1:13 pm     Reply with quote
If your changing a already existing program from a 4mhz crystal to a 20mhz crystal setup (ONLY) just look for these lines and change them
this might be in your programfilename.h file
from
#fuses NOWDT,XT,NOPUT,NOLVP
to
#fuses NOWDT,HS,NOPUT,NOLVP
and this
to
archcvd
PostPosted: Thu Jan 17, 2008 1:59 pm     Reply with quote
Fantastic. Thank you for all the suggestion folks. I will keep you posted as soon as I can.
