i2c routines for dallas ds1624, philips pcf8574, and 24cXX
Goto page Previous  1, 2
Post new topic   Reply to topic    CCS Forum Index -> Code Library
Dimlow
PostPosted: Wed Jan 02, 2008 1:29 pm     Reply with quote
Just wanted to add that if you look close at the READ FROM PORT and WRITE TO PORT line in these figures it explains it all. Also the note on the bottom of figure 12
Transfer of data can be stopped at any moment by a stop condition. When this occurs, data present
at the last acknowledge phase is valid (output mode). Input data is lost.
Regards
Gary
Dimlow
PostPosted: Wed Jan 09, 2008 1:24 pm     Reply with quote
No Comments ?
Gary
scanan
PCF8574
PostPosted: Wed Apr 09, 2008 9:22 am     Reply with quote
Here a code which run perfectly
I used 8 pcf8574 32 input and 32 output
#include <18F452.h>
#device adc=10
//#FUSES XT, NOPROTECT, NOOSCSEN, NOBROWNOUT, BORV45, NOPUT, STVREN, NODEBUG,NOLVP, NOWRT, NOWRTD, NOWRTB, NOWRTC, NOCPD, NOCPB, NOEBTR, NOEBTRB
#FUSES H4, NOPROTECT, NOOSCSEN, NOBROWNOUT, BORV45, NOPUT, STVREN, NODEBUG,NOLVP, NOWRT, NOWRTD, NOWRTB, NOWRTC, NOCPD, NOCPB, NOEBTR, NOEBTRB
//#FUSES  XT,NOPROTECT, BROWNOUT, NOPUT, NODEBUG,NOLVP, NOWRT, NOCPD
//#use delay(clock=10000000)
#use delay(clock=40M, oscillator=10M)
#USE RS232(BAUD=9600, XMIT=PIN_C6, RCV=PIN_C7,PARITY=N, bITS=8,STOP=1)
//use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
#use i2c(master,sda=PIN_C4,scl=PIN_C3,FORCE_HW)
#define ON  1
#define OFF 0
#define PCF8574_BASE_ADDRESS 0x40;
#define PCF8574_OUT0_WRITE_ADDRESS 0x48
#define PCF8574_OUT1_WRITE_ADDRESS 0x4A
#define PCF8574_OUT2_WRITE_ADDRESS 0x4C
#define PCF8574_OUT3_WRITE_ADDRESS 0x4E
#define PCF8574_OUT0_READ_ADDRESS 0x49
#define PCF8574_OUT1_READ_ADDRESS 0x4B
#define PCF8574_OUT2_READ_ADDRESS 0x4D
#define PCF8574_OUT3_READ_ADDRESS 0x4F
#define PCF8574_IN0_READ_ADDRESS 0x41
#define PCF8574_IN1_READ_ADDRESS 0x43
#define PCF8574_IN2_READ_ADDRESS 0x45
#define PCF8574_IN3_READ_ADDRESS 0x47
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#use fast_io(D)
#use fast_io(E)
void PCF8574_SendData(char writeaddress,char data)
//char writeadress,data;
   i2c_start();
   i2c_write(writeaddress);
   i2c_write(data);
   i2c_stop();
unsigned char PCF8574_GetData(char readaddress)
char data;
   i2c_start();
   i2c_write(readaddress);
   data=i2c_read(0);
   i2c_stop();
return data;
char data,i,addr;
   do{
   for(i=0;i<4;i++)
   addr=0x40+2*i+1;
   data=PCF8574_GetData(addr);
   PCF8574_SendData(PCF8574_OUT0_WRITE_ADDRESS,0);
   printf("INPUT NUMBER %d DATA %u\r",i,data);
   }while(1);
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
Page 2 of 2
