esa Guest
| Using Array of string |
Posted: Mon Jan 07, 2008 4:08 pm |
Dear Users,
I need help about using array of String. (for PIC18F4550+CCS V4.057)
In my program, I initialize two arrays :
char LCDstring [10][10]={"OFF","ON","CH.","t=","Alm.","CODE","XXXX","Alarm1=","Alarm2=","mV"};
char LCDstring2 [3][20]={"Input-Output type ","Calculation type ","Precision "};
Then, I use this array in a fct to print on a LCD :
lcd(LCDstring2[0],1,0,_CURSEURDROIT);
lcd(echelle,1,20,_CURSEURDROIT);
lcd(LCDstring2[1],2,0,_CURSEURDROIT);
lcd(courbe,2,20,_CURSEURDROIT);
When I use the first array, it's working, but the second array, I don't have a good result ( on LCD, I see other variable)
Where is the problem ?
The solve my problem, I make this :
strcpy(strmenutemp,"Input-Output type ");lcd(strmenutemp,1,0,_CURSEURDROIT);
strcpy(strmenutemp,"Calculation type ");lcd(strmenutemp,2,0,_CURSEURDROIT);
strcpy(strmenutemp,"Precision ");lcd(strmenutemp,3,0,_CURSEURDROIT);
But, I prefer to understand my mistake.
More questions :
What is the difference between :
const char unites[] [*]={"ppb ","ppm ","mgr/l","ugr/l","% "};
const char* pan_ids[] = {"aaaa", "bbbb", "cccc", "dddd", "eeee"};
char const *pan_ids[] = {"aaaa", "bbbb", "cccc", "dddd", "eeee"};
const char unitess[5][6]= { {"ppb "},{"ppm "},{"mgr/l"},{"ugr/l"},{"% "}};
In this case, I need to use strcpy, to place this string in a array.
I try to use a pointer directly on this array ( with PIC18). IT,s working in a program test ( little code), But, when I use the same code in my big program, I have wrong result.
This is my code : (working in a program test, but not in my big program )
compteurunit=0;
*unite=unites[compteurunit];
printf("\n\r unite=unites[compteurunit] unité %s",unite);
compteurunit++;
*unite=unitess[compteurunit];
printf("\n\r unite=unitess[compteurunit] unité %s",unite);
compteurunit++;
strcpy(unite2,unites[compteurunit]);
printf("\n\rstrcpy(unite2,unites[compteurunit]) unité2 %s",unite2);
compteurunit++;
strcpy(unite2,unitess[compteurunit]);
printf("\n\rstrcpy(unite2,unitess[compteurunit]) unité2 %s",unite2);
Regards |
Posted: Mon Jan 07, 2008 4:39 pm |
The test program shown below can read the strings from the array.
It displays this output:
| Quote: |
Input-Output type
Calculation type
Precision
| Code: | #include <18F4550.h>
char const LCDstring2 [3][20]={"Input-Output type ","Calculation type ","Precision "};
int8 i;
for(i = 0; i < 3; i++)
puts(LCDstring2[i]);
meereck
