Open-collector or open-drain output on a PIC
kender
PostPosted: Fri Jan 04, 2008 8:57 pm     Reply with quote
Colleagues,
This is, probably an easy question for those who know the answer. Is there a way to arrange an open-collector or open-drain output on a PIC18F4520 without adding a separate transistor? I think, according to the datasheet, the answer is “no”.
Thanks,
- Nick
Read the label, before opening a can of worms.
PostPosted: Fri Jan 04, 2008 10:43 pm     Reply with quote
Use these two functions to emulate an open-drain output:
output_low(pin #);
output_float(pin #);
kender
PostPosted: Fri Jan 04, 2008 11:02 pm     Reply with quote
Actually, I want the pin to have high impedance, when the PIC is powered down. Currently, I see that the pin is tied to ground, when Vcc = 0.
RLScott
PostPosted: Sat Jan 05, 2008 8:41 am     Reply with quote
The reason is that the protection diodes on the pin conduct toward Vcc. And if Vcc = 0, then any voltage higher than .7 volts will be shorted out.
Robert Scott
Ypsilanti, Michigan
coast
o/c output
PostPosted: Sun Jan 06, 2008 8:11 am     Reply with quote
open drain output does not require an external [spam] if you can constrain levels within the 0 to +5V range of yr power supply rails (or whatever yr PSU range happens to be). The internal protection diodes will dump energy back into the power rail above this level. If you DO need an external [spam] then ZVN3306 or sim. is normally a good bet (no other surrounding components). You may however choose to put a 1 meg pull down from gate to ground to control initial conditions (to make sure the [spam] is off during reset time)
coast
the wierdness of this site
PostPosted: Sun Jan 06, 2008 8:13 am     Reply with quote
Please note that the SPAM words in my last reply were what the CCS site chose to replace the word transistor with!!
Programmers can be very strange people.
PostPosted: Sun Jan 06, 2008 8:52 am     Reply with quote
It is worth remembering, that this is 'inherent' in the outputs of the PIC, without even considering any deliberate protection devices added. If you take a P channel FET, and ground the gate, and source, there will be an apparent diode seen if you try then to raise the drain.
SET
PostPosted: Wed Jan 09, 2008 2:02 pm     Reply with quote
We got caught out where we had a design that drove a triac optocoupler by current sinking into port pins. At power up there would sometimes be a glitch.. changing to source drive fixed it.
So the port pins definitely 'gulp' some current at power up - as to why:
1. Protection diodes - doubtful, as the pin and power pin will ramp up at the same time
2. P-channel FET - but if you raise the drain (i.e. the pin), the source would also rise (the supply) sot he inherent diode wont conduct?, and of course the gate shouldnt conduct...
There might be implications for battery powered systems, which are switched on and off - though I suppose the amount of 'gulp' current will be low.
spam, eggs, bacon and spam...
PostPosted: Thu Jan 10, 2008 10:11 am     Reply with quote
I noticed the above message and I wanted to test the spam out.
transistor, eggs, bacon and transistor.
So I typed; XSTR, eggs, bacon and XSTR. where XSTR is the full name - t r a n s i s t o r
Let's see if this works?
PostPosted: Thu Jan 10, 2008 10:13 am     Reply with quote
Nope - didn't work... I wonder how the other chap spelled the word - transistor that the board edited it out with [Spam]???
newguy
PostPosted: Thu Jan 10, 2008 10:17 am     Reply with quote
I bet it's either 1) trans or 2) tran.
1) T r a n s
2) t r a n
edit: nope.
SET
PostPosted: Thu Jan 10, 2008 10:44 am     Reply with quote
Try T r a n n y
[spam]
Yep :-)
asmallri
PostPosted: Thu Jan 10, 2008 11:02 am     Reply with quote
An easy solution to this is to add a Schottky diode, Cathode connected to the PIC output pin. The anode becomes the "open drain" output.
Regards, Andrew
PostPosted: Thu Jan 10, 2008 4:53 pm     Reply with quote
[spam], eggs, bacon and [spam]!
Yeah - Monty Python Lives!
