		| Author | Message |
		| arys
				| Build All Problem |
				|  Posted: Sun Dec 30, 2007 8:42 pm |   |
				| Hi, my problem is after build all. the  OUTPUT said " PCM" is not installed on this PC ". I use third party language. CCS ( IDE, PCM, PCH, PCB Version 4.009).
 What else I missed? Hope s'one help me.
 Thanks.
		| PCM programmer
				|  Posted: Sun Dec 30, 2007 8:45 pm |   |
				| Are you using the free PCB compiler that was included with MPLAB ? |  |
		| arys
				|  Posted: Sun Dec 30, 2007 8:56 pm |   |
				| Yes...I guess. Because the equipment was bought by my colleague. |  |
		| PCM programmer
				|  Posted: Sun Dec 30, 2007 9:29 pm |   |
				| This page shows which PICs are supported by each type of the CCS compiler.   The PCB compiler (included with MPLAB)
 only supports the most basic types of PICs.
 http://www.ccsinfo.com/devices.php?page=devices
		| arys
				|  Posted: Mon Dec 31, 2007 12:21 am |   |
				| yes..it support my PIC16f873. may be the main problem is not that I mentioned before.
 here I paste the whole output.
 Clean: Deleting intermediary and output files.
 Clean Warning: File "D:\........\CSD2145\2145 1.o" doesn't exist.
 Clean: Deleted file "D:\..........\CSD2145\2145 1.ERR".
 Clean: Done.
 Executing: "C:\Program Files\Microchip\Third Party\PICC\CCSC.EXE" +FM "D:\.........\CSD2145\2145 1.c" +DF +LN +T +A +M +Z +Y=9 +EA
 Error: The selected compiler: "PCM" is not installed on this PC
 Halting build on first failure as requested.
 BUILD FAILED: Mon Dec 31 14:15:08 2007
		| PCM programmer
				|  Posted: Mon Dec 31, 2007 5:34 am |   |
				| Are you using MPLAB ?  What version ?
 Did you install the CCS "plug-in" for MPLAB ?
 Is the CCS compiler or MPLAB installed on a Network Drive ?
		| arys
				|  Posted: Tue Jan 01, 2008 10:11 pm |   |
				| yes..i'm using MPLAB v7.60 and installed CCS plug-in already. both compiler and MPLAB was installed in my PC.
 Please..I don't have any idea to troubleshoot.
		| PCM programmer
				|  Posted: Tue Jan 01, 2008 11:35 pm |   |
				|  	  | Quote: |  	  | Clean Warning: File "D:\........\CSD2145\2145 1.o" doesn't exist. Clean: Deleted file "D:\..........\CSD2145\2145 1.ERR".
 Clean: Done.
 I can only suggest:
 Install MPLAB and the CCS compiler on the C drive.
 Put the project directory on the C drive.
 Put everything on one drive.
		| arys
				|  Posted: Tue Jan 01, 2008 11:50 pm |   |
				| i'll try. thanks.
 I just found out that in Select Device  menu, under Language and Design Tools is in  the red light which I assume it should be in green light. Correct me if i'm wrong.
 thanks
		| PCM programmer
				|  Posted: Wed Jan 02, 2008 12:08 am |   |
				| I think you mean that in the window, the word "COMPILER" has a red light.   That refers to Microchip products, not CCS.   Microchip doesn't
 have a compiler for that PIC.   CCS does.  Ignore the red light.
 Try this:
 1.  Go to the Project menu in MPLAB and then to "Select Language
 Toolsuite".  Make sure that the Active Toolsuite is:
  	  | Quote: |  	  | CCS C Compiler for PIC12/14/16/18 |
 2. Go to the Project menu in MPLAB and then to "Select Language
 Tool Locations".   Find the line where it says:
 and click on the little "+" box to expand that section.  Then click on
 the + box for Executables.  Then click on
  	  | Quote: |  	  | CCS C Compiler (ccsc.exe) |
 If you installed everything correctly, the directory should be:
  	  | Quote: |  	  | C:\Program Files\PICC\Ccsc.exe |
 If it isn't, then browse to that directory and locate CCSC.EXE and
 then select it as the location.
 3. Also look in C:\Program Files\PICC and make sure that you have
 the PCM.CRG file in that directory.   That's the license file from CCS.
 It's needed to run the compiler.   You must have it.  You get it from
 CCS when you buy the compiler.  They email it to you.
		| arys
				|  Posted: Wed Jan 02, 2008 12:45 am |   |
				| I go through the steps you ask. everything is OK but in toolsuite it has "CCS C Compiler for PIC10/12/14/16/18/24/dsPIC30/dsPIC33" which I think just ignore it.
 My windows can not open "pcm.crg" and its icon in 'C:\Program Files\PICC' is in the inappropriate icon which I have to open with some other programs.
 All *.c file in 'C:\Program Files\PICC\Example' also in inappropriate icons.
		| PCM programmer
				|  Posted: Wed Jan 02, 2008 1:22 am |   |
				|  	  | Quote: |  	  | I go through the steps you ask. everything is OK but in toolsuite it has
 That line is apparently from the current CCS plugin.   There has been
 some discussion on this board that not all versions of the "plugin"
 work with all versions of the compiler.    That might be the problem.
 I don't know.
