1-wire RS232
Goto page 1, 2  Next
apl01
1-wire RS232
PostPosted: Thu Dec 27, 2007 3:31 am     Reply with quote
Is there any way of using 1-wire for RS232 communication between many slaves and a master?
Thanks.
RLScott
Re: 1-wire RS232
PostPosted: Thu Dec 27, 2007 6:50 am     Reply with quote
Thanks.
Yes, sort of. I wouldn't call it RS-232, though. It would be a non-standard asynchronous serial half-duplex link. Instead of the usual RS-232 driver chips, use a passive pull-up and let each transmitter pull down the wire with an open collector or open drain. Your protocol will have to ensure that the master and slaves know when it is OK to transmit so they do not try to transmit at the same time. There is no reason to try to use RS-232 voltage levels, so you might as well use logic levels that are the same as your PICs. Since there is only one wire for both sending and receiving, each node (whether master or slave) will see its own transmissions echoed in its receive buffer. So you will have to be smart enough to recognize and discard those received characters. Other than that, and the loss of bandwidth that comes from using a passive pull-up system, there is no reason why this could not be used.
Robert Scott
Real-Time Specialties
Embedded Systems Consulting
SherpaDoug
PostPosted: Thu Dec 27, 2007 8:23 am     Reply with quote
I use a single TTL serial line to communicate between instruments on the bottom of the sea, where fortunately there is little electrical noise. Each end of the line has a DC blocking cap 1.0uF in case the cable gets mis-wired, and a series 50 Ohm termination resistor to the PIC pin. There is also a 10k pull-up resistor so the line idles as a stop bit, and a 0.01uF bypass cap to ground to kill noise from other wires in the cable..
The master sends a command and the slave responds. The slave never speaks unless spoken to. 1200 baud runs reliably over 1000 meter 24 AWG cables.
Sherpa...
PostPosted: Thu Dec 27, 2007 2:12 pm     Reply with quote
Hey I think I just put it together...
After years of reading about your interesting undersea projects...
Then I see Cape Cod on your profile - I'll bet you work for or at Woods Hole?
I was there several times - a nice little town.
Steve H.
SherpaDoug
PostPosted: Thu Dec 27, 2007 3:05 pm     Reply with quote
Like most of the engineers on Cape Cod I have at one time worked for the Woods Hole Oceanographic Institute. Now I am a consultant working for several oceanographic and ship husbandry companies. The oceanographic work is interesting, but the commercial shippers have the money.
Steve H
PostPosted: Thu Dec 27, 2007 3:46 pm     Reply with quote
Well I was close!
Steve H.
custom_elect
PostPosted: Thu Dec 27, 2007 6:45 pm     Reply with quote
Yes - I am an old dude.
But over 30 years ago - Intersil published a great 1 wire addressable half-duplex opto-isolated data aquisition network, the basis of which was used in many a good remote process control DATAQ system.
If you get stuck - email and I'll send some circuits.
roger@custom-electronics.co.uk
apl01
PostPosted: Thu Dec 27, 2007 10:34 pm     Reply with quote
OK so it can done. What do you mean by passive pull up system? I was thinking of making both master and slaves always in the receiving state by making the Tx pins as inputs i.e input(Tx). When the slave or master wants to send data the Tx pin becomes active sends data then resorts back to an input. Being new to comms would this work?
Thanks.
PostPosted: Thu Dec 27, 2007 11:55 pm     Reply with quote
Also see these two CCS example files:
c:\program files\picc\examples\ex_pbusm.c
c:\program files\picc\examples\ex_pbusr.c
gjs_rsdi
1 wire
PostPosted: Fri Dec 28, 2007 12:43 am     Reply with quote
as you say.
both TX input on start
TX and RX lines connected together
10k pull-up resistor on the line
difficult to chek if the line is active not to have bus colision
if one is master and others slaves, the master should manage the bus.
master transmits 55h,AAh,slave address, read/write &number of bytes for example, clear the bus. slave answers and clear the bus
joseph
custom_elect
PostPosted: Fri Dec 28, 2007 6:07 am     Reply with quote
But you have to be real careful about what happens when the power goes off one device - you dont want it to jam up the whole comms bus. Opto isolators are the answer.
Audi80
PostPosted: Fri Dec 28, 2007 7:31 am     Reply with quote
For more than one slave you have to use RS485 or you wont get any communication. Because RS232 is a serial port witch means that you have to put all devices in serie and with RS485 you use a parallel port with means that all devices are in parallel. And dont forget that with RS485 you can only connect 32 devices. Wink
SherpaDoug
PostPosted: Fri Dec 28, 2007 8:41 am     Reply with quote
The problem is when both ends are inputs and the line is floating. If it happens to float to a Start bit voltage both ends will think the other has begun a sending a byte. They will both start clocking in serial bits till they get to the Stop bit when they will probably get a framing error. Avoid all this by rigging a resistor to pull the line to the Stop bit voltage when not being driven by anything else.
SherpaDoug
PostPosted: Fri Dec 28, 2007 8:46 am     Reply with quote
If the master powers the pull-up resistor and the slaves all use open collector (or open drain) output drivers and high impedance inputs, then only the master must have power for the bus to function.
gjs_rsdi
1 wire rs232
PostPosted: Fri Dec 28, 2007 12:53 pm     Reply with quote
rs485 has +tx/+rx & -tx/-rx lines and select between tx and rx by software and hardware
1 wire rs232 has tx/rx line and select by software
they are the same. you can put the slaves in parallel in rs232 same as in rs485 or TTL levels. no difference.
and the line can't float if have 10k pull-up resistor
joseph
Goto page 1, 2  Next
Page 1 of 2
